cooling down
Old May 16, 2008 | 09:20 AM
Gronmore's Avatar
cooling down
Alright sorry if this has already been addressed used the search and didn't find any thing.
well when i turn my car off it dose its normal cool-off thing but it seams like it dosent
stop... it was going for a good 45mins so i put the key in and turned it to standby then off and it stopped it.
could i have a problem with my coolant or might there be a problem with it shutting of due to programing issues on the ecu?
Old May 16, 2008 | 09:24 AM
mysql's Avatar
Doppelgänger
I'm glad you searched, because this is a hot topic that no one has an answer to. Your car is indeed overheating and will not last more than a week at it's current pace.
Old May 16, 2008 | 09:25 AM
mysql's Avatar
Doppelgänger
Also, everything in my previous post was a lie.
Old May 16, 2008 | 09:26 AM
649.7 degrees!
Shouldn't run any longe than a few minutes.
Are you stretching the true like Hillary?
Old May 16, 2008 | 12:21 PM
Nubo's Avatar
Lubricious
When it gets really hot, the car will run the fan for a long time. Not sure about 45 minutes but I've had it go on for a half hour for sure. Don't do the key thing to make it stop -- the cooldown process is important. If you want to help it out, raise the hood to help heat escape (asuming you're in shade). Don't worry, running the fan for an hour shouldn't kill your battery. If it does you need a better battery.
Don't run this car hard when it is over 100F.
jDt!
Oct 2, 2015 04:04 PM
Draken
Sep 21, 2015 06:14 PM
carid
Vendor Classifieds
Sep 10, 2015 09:26 AM
