Going drag racing tonight!!
Old May 14, 2008 | 06:27 PM
Renesis07's Avatar
Vtak just kicked in yo!!
Going racing again tonight. For those who remember I went for my first time about 2-3 weeks ago and ran a 15.5@89 mph with a terrible launch.
>Does this sound right? Launch at 4-5K feathering the clutch
>What psi should be in my rear tires, I had 35psi all around last time. Does 20psi sound right?
*Im still learning drag racing and my car is lightly modded. CAI, midpipe, lowering springs. I want to get my car into the 14's, just to prove to myself that my engine still has compression because Im so paranoid lol. And my goal is 91-93mph trap speed, last time it was 89 which is very low for an RX8.
Goal: mid-high 14's @ 91-93mph.
Feel free to give advice/comment. Ill post times around 10pm cali time when I get back
Old May 14, 2008 | 06:31 PM
Jasonawojo's Avatar
Good luck!
20psi seems a bit low?
Old May 14, 2008 | 06:35 PM
Renesis07's Avatar
Originally Posted by Jasonawojo
Good luck!
What would you recommend? I more or less just threw a number out there
Old May 14, 2008 | 06:40 PM
flyboi1121's Avatar
werD?
i go with usually 32-34 psi. rev to like 7k and feather it from there with the dsc off. i got 14.8 with the same mods you have (without the springs) you shift like u stole it and drop it from 8k, probably get like 14.5 lol
Old May 14, 2008 | 06:42 PM
Renesis07's Avatar
Thats what I did last time but I got really bad wheel hop.
LOL, maybe I should leave my subs in this time so I wont have wheel hop
Old May 14, 2008 | 06:49 PM
xsnipersgox's Avatar
One Shot One Kill
wouldn't chalking work for u too?
Old May 14, 2008 | 06:56 PM
Renesis07's Avatar
what is chalking? Or was that some sort of insult lol?
Old May 14, 2008 | 07:39 PM
Z1NONLY's Avatar
In autocrossing many people put chalk marks on their tires from the sidewall to the tread. The parts of the chalk that get scuffed off let the drivers know what parts of the tire are being used.
I have only been to two different drag strips so I don't know if this method is used to set tire pressures the same as in autocrossing. (But I am guessing it could help)
Old May 14, 2008 | 08:44 PM
wassup_nuthin's Avatar
first of 35 pounds is way too much air, i mean its ok but yea... run about 25-27 pounds, if your on stock tires dont launch that high i would recomend 4k launch stock tires hook worth schit
Old May 14, 2008 | 09:38 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Let us know what you decide to do and how you do.
Old May 14, 2008 | 09:44 PM
chancejat's Avatar
Drive it like u stole it!
dont shift hard try to shift smooth into second gear...kinda give it a quick little feather, jerky shifts slow you down, also heat/spin your tires before each run, very important because it cleans the tires off, may also help with your wheel hop, if your goal is to trap 93 then dont even bother with 4th gear just redline third....edit:i think im too late
Old May 15, 2008 | 12:35 AM
Renesis07's Avatar
wow, okay. Each time I ran I would perfect one thing but screw up on another.
I ran a 15.9 @ 92 mph with a 3.9 sec 60' and probably the worst launch ever. (Stayed in 3rd, never shifted) (6K feathering *attempt*)
Next I ran a 15.4 @90 mph with a 2.3 sec 60' time but my reaction was .8 seconds....WOW (PERFECT 5K LAUNCH FEATHERING)
Last I ran against a Civic Si, I ran a 15.8 @ 88 mph and actually won lol.
(5k feathering but wheel hopped)
My car has trouble getting into 4th so my best trap time so far has been ran in 3rd at 92 mph. If I could take all the attributes from each race and just run one perfect run I have absolutely no doubt I would be in the 14's.
Fun night, I was the only rotary there so I learned a lot and Im slowely accepting that my car is not a drag car. Im glad I trapped 92 so at least I know my cars engine is still good lol. Feel free to comment/give advice.
Old May 15, 2008 | 10:17 AM
dozer's Avatar
on his 3rd rx8
way to go!!!!
Old May 15, 2008 | 10:41 AM
dshiznit1489's Avatar
Formerly Polak Graphics
cool story hansel.
Old May 15, 2008 | 11:12 AM
C Ya L8r's Avatar
deer all noobs: reaction time has nothing to do with 1/4mi time. The clock does not start till you move.
looks like you need to work on your launch. Maby the track is kind of slick.It helps to ask other drivers what they are getting. Also street tires dont like heat just give them a quick spin outside the water box to clean them up. Spinning in the box will throw water up in the wheel wells and it will drip back on the tires when you are wating to launch.
Old May 15, 2008 | 11:17 AM
superglue's Avatar
n00b post whore
Originally Posted by Dshiznit1489
cool story hansel.
That made me lol out loud.
I've never even been to Mt. Vesuvius
Old May 15, 2008 | 11:47 AM
eviltwinkie's Avatar
wow, okay. Each time I ran I would perfect one thing but screw up on another........................................I trapped 92 so at least I know my cars engine is still good lol. Feel free to comment/give advice.
FROM: https://www.rx8club.com/showpost.php...postcount=2663
Originally Posted by eviltwinkie
Oddly enough...from 7k...with lots of initial wheelspin on RPF1's/275's was the fastest...which was counter to what I've found before which was to dump at 5.5k...
Back then I didnt have this much traction, power, or suspension modifications...
Unfortunately I'm having 2nd/3rd gear syncro issues...so I havent done a 0-60 test for a looong time...most of the track stuff doesnt really demand lighting fast shifting so its not a huge issue yet...I'm also trying to be as gentle as possible...
I'm also not used to the additional 9 ft/lbs of torque from the stage 3 maps...heh
Chalk your tires...and get yourself some sway bars for your wheel hop issue...clean your car out...and run it with 1/2 tank of gas...
According to the CobbAP (unverified claims basically...not a track slip from a calibrated system) I am able to consistently get 0-60 in 6.0 (+/- 0.40) seconds on average and I have seen 5.6 seconds once...and the 1/4 at low 14s...easily...
Until I get a time slip from a track...I'm not really trusting the results...
Old May 15, 2008 | 02:30 PM
Renesis07's Avatar
I have a GT with sunroof, leather, sound system, etc. My buddy and I are going to gut out the interior next time just to see how much that will affect it.
Im really not trying to master this sport of drag racing just having fun lol.
Old May 15, 2008 | 02:39 PM
I dont like drag racing either...I'm much more of a road course pWn t3h tw1steuhas kinda guy...but I have to go against a GTO soon, so its something that I've recently had to think about...and thus, am only offering simple advice...
With the exception of the sways...get those period...they pWn something fierce...
Old May 15, 2008 | 05:35 PM
I love drag racing! its my favorite by far! But then again i grew up w/ chevelles and camaros so i guess its in my blood. I like the road coarse too, as i have not done it on a track i know i will like it and will be doing it at the drag strip here also. *drag strip also has a track coarse*
**oh by the way chevelles arnt my time period just all my family had them, im only 22**
Old May 16, 2008 | 12:01 AM
Max in 3rd gear is 91.
Old May 16, 2008 | 12:26 AM
Renesis07's Avatar
clocked me at 91.8 and my speedo read 93. My speedo is off, Ive confirmed that with those cop things that tell your speed lol. Its about 2-3 too fast.
Old May 16, 2008 | 12:37 AM
Ike's Avatar
Ike
Blue By You
FYI, your R.T. has no bearing on your E.T.
And, uhhh, way to put the smack down on that Civic with the 15.8...
Old May 16, 2008 | 12:39 AM
Renesis07's Avatar
He ran a 16.9. So I looked like a stud
Yea I already learned that about the RT. Noob to drag racing, Im still learning
Old May 16, 2008 | 09:42 AM
Bester's Avatar
07 6M Black
How high above sea level are you? Your time at high elavations will be slower than at sea level.
