RPMs stop at 7K
Old May 13, 2008 | 07:55 PM
Gdawg522's Avatar
Rotary Addict
RPMs stop at 7K
Hi everyone,
I was out last week with some friends and we were doing some spirited driving. Hard acceleration and lots of redline shifts. Well after doing this for about an hour the engine was pretty hot I'm guessing. This was when I noticed that I couldn't redline it anymore. It would just stop around 7K and bog down like the gas was cut off. Does anyone know what causes this. I thought I killed my 13B but it was fine the next day.
Old May 13, 2008 | 09:16 PM
bad cat or coils.
Old May 13, 2008 | 09:18 PM
WAR CRUNK's Avatar
U.S ARMY 11B
cat check that
chancejat's Avatar
Drive it like u stole it!
probably your cat/coils or your last 2 ports are locked up.... but i doubt that....lol
Old May 14, 2008 | 03:30 PM
Gdawg522's Avatar
Rotary Addict
Well what is weird is that the engine was fine once it cooled for two hours and I took it back out. I'm guessing that the PCM could shut off the last two ports due to excessive temperatures. That is just a guess. The car has been running great now. It only did it that one time when I was really driving it hard.
Old Jun 1, 2008 | 12:42 AM
Nemesis GP's Avatar
Hi all, please help my car has been giving me grief for sometime now. Previously she would cut off at 7500 rpm and after driving a while the engine would cut off completely. I no longer have a cat as we dont have such strict emissions rules here in south africa-so all the sensors are still in place and the original cat was replaced with a normal back box-this was about a year ago-now the stalling happens quite often once the car is hot(after about 80-90kms)-I have replaced the coils/plugs and plug wires yet there are still flat spots through the rev range and at times she redlines at 7500rpm she even switched off yesterday when I changed to a lower gear and revs went up...please help any advice will do!!!
Friends here have suggested the air flow sensor behind the air filter or possibly the fuel filter/fuel pressure regulator. On start up at certain times she also smokes heavily and its thick white smoke that comes out but stops after a drive her a bit hard in first gear.
Old Jun 1, 2008 | 08:19 AM
What kind of oil weight were you using?
It sounds like your engine is dying, Lack of lube ? Premix ?
Old Jun 1, 2008 | 06:49 PM
Nemesis GP's Avatar
well im using caltex 20w50
Old Jun 1, 2008 | 07:13 PM
Get the Access Port. It will tune your car.
I hope your engine isn't going bad.
Old Jun 2, 2008 | 08:58 PM
Nemesis GP's Avatar
ACCESS PORT? Please enlighten me as I have no idea what this is
Old Jun 3, 2008 | 09:42 PM
how many miles on plugs and coils?
Old Jun 3, 2008 | 10:38 PM
xsnipersgox's Avatar
One Shot One Kill
Originally Posted by Gdawg522
Hi everyone,
i want you to give this a try.
warm car up, find a large empty parkinglot. get ur gas to about 1/3 to a 1/2 a tank.
i want you to speed up to about 50mph give or take, maybe even 60, heavy breaking into maybe 35-40mph (i want you to stay in 2nd gear, the rpm should be about 4-5000rpm, 1/2 throttle) , and ease into a large gentle wide sweeping left turn, slowly pull the turn tighter and tighter as the tire will safely allow you to do so (u should experience more and more side G force). Hold this turn for about 5 seconds, then do a right hand version, than just keep trying the left turn version.
What i am testing for here is faulty fuel pump, my fuel pump was going out and this was my sure fire way of reproducing the problem at command for the dealership service writer. if the fuel pump is going out, near the end of the high G sweeping left, your engine should show the same symptom as you have mentioned.. if not, look elsewhere for problem.
remember, safety 1st.
Old Jun 3, 2008 | 10:46 PM
i have a new pump and i can do that on a track with 3/4 tank of gas..
Old Jun 3, 2008 | 11:10 PM
One Shot One Kill
true but u have slicks =p
Old Jun 3, 2008 | 11:13 PM
nope,
just daily street tires. and little talent. i have a hunch as to what it is. have part on order..
Old Jun 3, 2008 | 11:18 PM
https://www.rx8club.com/series-i-trouble-shooting-95/gotta-love-reliability%3B-tune-%24698-00-a-147047/
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
D13
Oct 1, 2015 07:55 AM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
tommy26Germany
Sep 29, 2015 10:33 AM
