New Recall Canada
Old May 9, 2008 | 05:33 PM
New Recall SSP 76 Canada only??
New Recall in Canada anyway....04-08 RX-8's
SSP 76 Oil Cooler Hose Special Service Program
On certain RX-8 Vehicles the oil cooler hoses may show premature amounts of corrosion due to the deposition of muddy water containing road salt, which may cause perforation. Under severe conditions this may result in an engine oil leak
Old May 9, 2008 | 05:35 PM
shaunv74's Avatar
Power!!
I suspect the guys in AZ won't see much of this.
Old May 9, 2008 | 08:37 PM
NYC use snow salt like nutz, even when there were NO SNOW !
Maybe I should check mine
any idea whats the new part number ?
Old May 9, 2008 | 08:44 PM
F1Y1-56-14Z
F1Y1-56-13Z
N3Y6-14-S70
N3Y2-14-S70
N3Y3-14-S70
5555-EG-001R
That's if they have to replace all 3 hoses, Gasket etc.
2.1 hrs labor for all 3
Old May 9, 2008 | 09:06 PM
BlueFrenzy's Avatar
Rotary Powered Decepticon
Dannobre .. did you get a letter or something for this?
Old May 10, 2008 | 12:10 AM
Was in the dealer today...they told me about it....Have the paperwork on my desk
Old May 10, 2008 | 12:27 AM
F1Y1-56-14Z
F1Y1-56-13Z
N3Y6-14-S70
N3Y2-14-S70
N3Y3-14-S70
5555-EG-001R
Cant find those hmm ... maybe Canada has diff part number ?
Old May 10, 2008 | 01:01 AM
Silver06's Avatar
Zoom Zoom....
Dan, Thanks for this!
Old May 10, 2008 | 04:32 AM
slidey's Avatar
We've had this recall for about 3 months now in the UK, and we've had oil lines going through in cars less than 3 years old!, MAZDA have changed the plating on the pipes and also done a wheel arch mod to seal the area, although i'm not happy with MAZDA's dodge which involves sealing the arch with silicon!
We've also had trouble with SUMPS rusting through, so we might see another recall for this.
dave
Old May 10, 2008 | 06:34 AM
wcs's Avatar
wcs
no agenda
^^^wow
I'm going to check mine, even thou my car is not winter driven.
I have mazda replacing the rear quarter panel due to rust and it's only a 05!
Old May 10, 2008 | 09:31 AM
I was surprised how corroded mine were...in an area where we use very little salt.
You guys on the East Coast where they dump the stuff on the roads in the winter must really have a problem.
I figure they are doing a roll out type of recall...that way they don't get everyone scrambling for parts at the same time...
Old May 10, 2008 | 12:02 PM
shaunv74's Avatar
Power!!
Are they improving the parts or just replacing them?
Old May 10, 2008 | 12:14 PM
turborx8's Avatar
Boost 4 Life
Where are these hoses?
I drive my car in the winter so I am sure mine are toast.
Old May 11, 2008 | 04:17 AM
slidey's Avatar
The parts MAZDA use are an improvment over the old ones in the fact they have changed the protective coating on them, the old ones are sort of a silver/gold colour, to access them you need to remove the front wheels and inner arch linners, you'll then see the pipes.
dave
Old May 11, 2008 | 07:53 AM
the hose that goes from engine to left oil cooler, then from the left to the right cooler, then back to engine.
I think I see what you mean, I just looked at mine and yea it is showing corrosion.
Sooner or later MNAO have to patch this sucker.
Old May 17, 2008 | 12:24 PM
I talked to the dealer yesterday...they are only replacing the hoses that are leaking...but they have not put a time limit on when the hoses can be replaced...
Another thing they are doing is retrofitting the fender liners...and removing the vents behind the oil coolers...not sure I'm liking that...I think I will leave mine alone...I can't see how closing those vents will help the cooling of the engine in any manner
Old May 17, 2008 | 02:24 PM
LiTTleRX-8's Avatar
mis-shift_DOH
I was part of the recall when I brought her in for oil change in early May. They didn't have the parts to do it, so mine are not done yet.
The recall came out at the end of April 08.
Old May 17, 2008 | 03:34 PM
MazdaJeff's Avatar
I had mine done yesterday. Said he changed all the hoses. Also, said it took them close to four hours of labour.
theblinkof
Oct 4, 2023 05:24 PM
gwilliams6
General Automotive
60
Nov 3, 2015 02:50 PM
1webbdan
Oct 31, 2015 07:57 AM
Sheldon24
Sep 21, 2015 04:53 PM
