Calling all MOUNTED AccessPORTS...
Old May 7, 2008 | 08:27 PM
0_o Flash's Avatar
I just want to see if anybody has figured out a good way to mount it yet.
Old May 7, 2008 | 08:30 PM
VarneyMazda's Avatar
Northeast Pimpin'
Check the AP thread there's a few pictures in there
Old May 7, 2008 | 08:32 PM
mysql's Avatar
Doppelgänger
mine's mounted in the glove box.
Old May 7, 2008 | 08:35 PM
0_o Flash's Avatar
Yea I dug threw like 20+ pages and got a little aggravated....
Old May 7, 2008 | 08:46 PM
turborx8's Avatar
Boost 4 Life
I posted this a few times. Here it is again.
Old May 7, 2008 | 09:07 PM
devildog1679's Avatar
3M velcro. Comes off with ease.
Attached Thumbnails Calling all MOUNTED AccessPORTS...-hpim0313.jpg   Calling all MOUNTED AccessPORTS...-hpim0312.jpg
Old May 8, 2008 | 06:48 AM
r0tor's Avatar
I went with the crappy cell phone mount... works, just not very well
Old May 8, 2008 | 11:42 AM
\\Konig\\'s Avatar
turrrbo!
i have a cell phone holder from best buy that costs 11 dollars. works good, holds the AP pretty solidly in place (minimal wiggle) and is in the same location as the one in the previous picture over the vent. there was basically no instructions that came with it though and it had a bag of small parts but i eventually figured out the puzzle haha.
i said i was going to take a picture of it a while back, ill do that today! promise! haha.
Old May 8, 2008 | 11:56 AM
TopGear8's Avatar
mkuhnracing.com
turborx8 when did you take that pic? 36 degrees is pretty cold! I've been enjoying 70 degree weather.
Old May 11, 2008 | 09:26 PM
\\Konig\\'s Avatar
turrrbo!
okay sorry kinda late, but here is the pictures of my holder
Old May 12, 2008 | 12:14 AM
Konig: looks sweet!
Old May 12, 2008 | 01:04 AM
\\Konig\\'s Avatar
turrrbo!
thanks! sorry i lagged on taking the pictures, i know i told you id take them a long time ago...!
Old May 12, 2008 | 01:23 AM
MazdaManiac's Avatar
+1
Old May 12, 2008 | 09:59 AM
random question: what are you guys monitoring most of the time? Mounting the AP when you first load a map is nice but after a while...
Old May 12, 2008 | 11:18 AM
\\Konig\\'s Avatar
turrrbo!
99% of the time im on the AFR readout
i just like watching it for some reason haha, its interesting
Old May 12, 2008 | 11:36 AM
That is what I would do.
Its the most important display in the group.
Old May 12, 2008 | 11:39 AM
Red Devil's Avatar
Are you using auxiliary AFR also, or have you found the factory wideband accurate enough?
^^^ yeah, but you cheat. Your AP is in the glovebox. That Jet Fighter cockpit you call a car has the readouts on it already.
Old May 12, 2008 | 11:42 AM
Its not accurate enough for FI tuning, but it is plenty good enough for monitoring.
True.
Old May 14, 2008 | 11:44 AM
nuke0907's Avatar
Never Blend In
one of the best setups i've seen in WantedTwo's ride.
Old May 14, 2008 | 11:55 AM
\\Konig\\'s Avatar
turrrbo!
looks expensive though...lol.
where does the wire run through?
Old May 14, 2008 | 12:11 PM
nuke0907's Avatar
Never Blend In
i think it goes through the console. you'd have to ask him. i didn't get any pics from the other side either.
Old May 14, 2008 | 12:20 PM
Highway8's Avatar
Registered RX8 Nut
I dont know about other states, but in california you wont want to get pulled over with the access port mounted. It is a quick trip to the referee which means a $350 fine plus the hassel of a smog check.
I keep mine in the pass through storage area. For AFR monitoring I use the MSD dash hawk, I can also see coolant temp, STFT, LTFT and every other stock sensor.
Old May 14, 2008 | 12:59 PM
\\Konig\\'s Avatar
turrrbo!
yeah true, luckily its easy to unplug and put out of sight in case that happens!
Old May 14, 2008 | 01:42 PM
pgrothe's Avatar
I know that the AFR must be checked after a reflash, but for a noob like, what would be a correct value. Currently at WOT, I'm in the 14,5 area which seems to be a bit high.
I am using the REVI intake. If this value is too high, what would be the consequences ? I'm not using my car that much, maybe 300 km a month, but WOT is used for sure every time I use my car
Thanks, for you help
