Seat Installation Help
Old May 5, 2008 | 08:16 PM
hry_glb's Avatar
Gas Station is 2nd home.
Hi all,
I'm going to change my damaged front driver side seat with another OEM one. This is my first time changing a seat so I'm not that sure.
Question:
- After unplugging the negative battery, should I keep the cable unplugged? Or should I attach it back (I'm going to take the seat up to my room for cleaning) Will it do anything bad to the ECU?
Old May 5, 2008 | 09:25 PM
expo1's Avatar
He's as bad as Can
Why on earth would you disconnect the neg Batt cable to change a seat??? I have swapped seats a dozen+ times for track weekends and never touched the Batt cables.
Old May 6, 2008 | 02:53 AM
N rider89's Avatar
^NieL
instructions ive seen say to undo the battery because of the airbag. guess you proved that wrong
Old May 6, 2008 | 01:33 PM
hry_glb's Avatar
Yeah, airbag is my concern as well. Again, it's not a racing seat or aftermarket one, it's just simply an OEM swap. So what should I do here?
Old May 7, 2008 | 06:28 PM
hry_glb's Avatar
Ok so I would assume it's simply removing the bolts, taking off the harness and cable and swap it. I'll try it tomorrow, Thanks a lot
Old May 7, 2008 | 08:35 PM
VarneyMazda's Avatar
Northeast Pimpin'
Disconnect the battery, then after that unhook all the harness connectors under the seat, after that its only 4 bolts holding the seat down. You'll prolly need an impact gun to take them off.
Olorin2
20
Mar 13, 2016 11:01 AM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
Tsurugi
Sep 7, 2015 08:27 PM
