Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
Where y'all get alignment at?
Old May 2, 2008 | 07:39 AM
xsnipersgox's Avatar
One Shot One Kill
i was at sears auto place and they say it may be 100 bucks?
houston please., thanks.
Old May 2, 2008 | 07:54 AM
Creto's Avatar
It's good to be the king.
you can get it for less... typically around 70-80ish. Or, if you think you'll need it more than once in the life of your car (pretty good bet), Firestone offers a lifetime alignment for something like 140 (if I recall correctly).
one thing to keep in mind (at least at Firestone) is if you've changed your ride height, you'll need to provide the custom specs for your alignment based on the geometry of your car, otherwise they will use the stock specks and you'll likely end up with a bad alignment.
Old May 2, 2008 | 11:46 AM
Decat's Avatar
Yeah exactly, I just did this and I always go to Firestone because there's is a lifetime alignment, that means pay $130 ($140 with tax) and then you could change your suspension, hit something, let it settle, whatever you want and get it aligned every month if you want no extra charge. if you might get it aligned more than once than Firestone is the best deal for lifetime alignment. There is a great Firestone on Kirby just south of 59 (inside the loop) they are good guys there.
Old May 2, 2008 | 11:48 AM
One Shot One Kill
ya, i wanna get it aligned before each autocross event if possible.
Old May 2, 2008 | 12:27 PM
987HYS's Avatar
Dragon Certified
I got mine done at the dealership. 89.95 or something like that
redrx82015
Aug 17, 2025 01:10 PM
gwailo
May 14, 2024 06:57 AM
blainezoomzoomrx8
Sep 9, 2017 08:29 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
thewatcher101
Jul 27, 2015 09:44 PM
