well i just got the famous FLOODING prob!! arrrgh
Old Apr 30, 2008 | 10:38 AM
tvtech3's Avatar
Towtruck on its way after calling mazda roadside service for my 04 rx8 w/22k orig on it.
I went out this morning to leave and it just keeps turning over and spiting strong gas vapors out the tail pipes
Old Apr 30, 2008 | 10:43 AM
Greenblurr93's Avatar
Sotally Tober
did you try and prefprm the deflood procedure first?
Old Apr 30, 2008 | 10:53 AM
CyberPitz's Avatar
Huge hole is huge
I'd sure hope :P
But if you did, tough break man.
Old Apr 30, 2008 | 11:01 AM
Socr8tes's Avatar
Did you shut it down cold? Do you have the updated starter, plugs, battery, flash?
Old Apr 30, 2008 | 02:37 PM
tvtech3's Avatar
Yea ive got all the latest updates/plugs etc etc and for some reason it just happened. The car only has in the low 20k,s in mileage
I rode w/the towtruck to the mazda dealer/service dept and w/in 1 hour it was ready,,, i seen the guys working on it from a distance,, they never took it in to the gargae itself but just outside the garage where they loooked to have taken some type of can of spray and squirted it into some part of the engine and it started and they frikken revved it hard and i mean hard wide open to where the cut off was kicking in and held it there for quite some time and smoke poured out the exaust,, actually i was worried about them revving it so high and for so long, but i guess they know what they are doing>>?????? i hope so. but that was it and i s im back home w/it as it didnt take long.
And yes i tried all the flooded engine tricks but no go,, it would sometime act as if it was going to start but didnt,,,,, i wonder if they just sprayed starting fluid in the air intake?
Old Apr 30, 2008 | 10:42 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Good luck. Sorry to hear!
Old Apr 30, 2008 | 11:09 PM
Blazed's Avatar
Probably sprayed some starter fluid or engine cleaner. I hope they let your engine warm up before they started revved it that high and hard. Does anyone know if what they did is bad for our engine? Especially if the engine is not warmed up?
Old May 1, 2008 | 02:07 AM
Bumble_Bee's Avatar
"Autobots Roll-Out..!"
So how much did they charge you??
Old May 1, 2008 | 07:11 AM
tvtech3's Avatar
There was no charge as its still under warranty thru aug 08 and the towing was free also,,,,, and to the other poster,, no the engine was dead cold when they did the hi revs, i also wondered the same
Old May 1, 2008 | 08:20 AM
Socr8tes's Avatar
If it was cold, the ECU should have limited the revs to 7k(?) to protect the engine.
Old May 1, 2008 | 05:02 PM
Raptor75's Avatar
More likely some type of oil to allow the seals to function. The over load of gas prevents this sealing action and therefore prevents compression, result is no start. The oil allows the seal to function again and the high revving with lots of smoke would be them burning off the oil in your combustion chamber after it starts.
Of course I don't know this for a fact but it would seem to make sense.
Old May 1, 2008 | 10:34 PM
car is ok?
92trbolzr
May 18, 2025 09:04 AM
DylanForbes
25
Oct 31, 2017 05:47 PM
fistofmeat
Oct 7, 2016 12:15 PM
Danield97
Oct 10, 2015 05:58 PM
TJSiegrist
Sep 10, 2015 09:29 AM
