mounting a radar detector
Old Apr 24, 2008 | 05:30 PM
Runmymouth's Avatar
hate break in period
I was wanting to mount a radar detector on my car and was wondering where people would recomend to go get this done. By mounting I mean not having the cord run down to the cigarette lighter.
Old Apr 24, 2008 | 05:31 PM
Spinning Sushi's Avatar
I <3 Sushi
That's why we hardwire it into our rear view mirrors. Run a search on it, you'll find it.
Old Apr 24, 2008 | 05:41 PM
Willie27's Avatar
Run a search on it, I have some pics on this site somewhere. Bought the mount from a corvette site (also listed in the thread) and hard wired it to the mirror power.
Old Apr 24, 2008 | 05:44 PM
Willie27's Avatar
Here you go: Page 2 are my pics.
https://www.rx8club.com/series-i-tech-garage-22/valentine-1-passport-8500-a-85411/page2/
Old Apr 24, 2008 | 06:09 PM
valpac's Avatar
Ahead of its time
I hardwired mine to the overhead console. Very easy.
Old Apr 24, 2008 | 06:36 PM
here ya go:
http://rotaryinsider.com/rx8-60.html
Old Apr 24, 2008 | 08:44 PM
Runmymouth's Avatar
Would this void my bumper to bumper warranty on the power systems? Also saw these http://www.stealthcords.com/shop/home.php and was wondering if anyone had used them?
Old Apr 24, 2008 | 09:31 PM
would not void your warranty. Mazda would need to prove that splicing wire off that mirror caused some type of failure. (which is HIGHLY unlikely if this is done properly)
Old Apr 24, 2008 | 09:34 PM
Runmymouth's Avatar
What if some of us bought the detector before reading the parts about having the hardware kit? Anyone have a recommended hardware kit? Bought http://www.amazon.com/Vector-High-Pe...6ADW2QF40J7Y28 or the BEL Vector 955. Also I keep seeing some sort of mod where your cigarette lighter used to be, what is that?
Old Apr 24, 2008 | 09:45 PM
what kind of radar detector do you have?
Old Apr 24, 2008 | 09:46 PM
Runmymouth's Avatar
Bel Vector 955
Old Apr 24, 2008 | 10:19 PM
That's a nice setup.
Old Apr 24, 2008 | 11:06 PM
check with Bel, see if you can order the cable from them.
Old Apr 25, 2008 | 02:09 AM
laythor's Avatar
I zoom therefore I am.
did a search on ebay and found the hardwire kit for Bel Vector 955 at 8 bucks.
Old Apr 25, 2008 | 09:37 AM
amstarvid's Avatar
ZM ZM X 8
If you don't want to wire into the homelink mirror (or don't have), the hard wire cord is long enough to run along the inside of the headliner and down to the fuse box, where you can tap in using an "add a circuit" fuse. That's what I did instead of wiring into my homelink - there are good directions in the DIY section for this method as well.
Old Apr 27, 2008 | 12:15 PM
Runmymouth's Avatar
I bought http://www.stealthcords.com/shop/pro...cat=276&page=1 and http://www.countryjoycrafts.com/350Z/escortmount.htm and I will let y'all know what I think of the stealth cord. I like the way Jedi has his setup, and good starting point to start looking from.
Old Apr 27, 2008 | 05:06 PM
CompMan's Avatar
iDüber
I can't find the DIY, since I'm trying to wire it into my fuse box also. and It doesn't work.
Old Apr 27, 2008 | 08:25 PM
amstarvid's Avatar
ZM ZM X 8
https://www.rx8club.com/showthread.p...radar+hardwire
There's the link - scroll down about halfway til you see the 2nd post from "robertdot" - I think there's some more pics further on. You will need an "Add a Circuit" fuse adapter - it may take looking at a few different auto parts stores in the fuse area - some have it, some don't. I've had mine this way for 2 years and like it a lot.
Old Apr 27, 2008 | 09:57 PM
CompMan's Avatar
iDüber
okay, thanks a lot man.
Old Apr 28, 2008 | 07:47 AM
amstarvid's Avatar
ZM ZM X 8
No problem - it's a really easy install -
Old Apr 28, 2008 | 12:38 PM
8 Maniac's Avatar
Senior Member
If you didnt feel like hard wiring it and dont mind the cable being somewhat visible, then you can do What I did. I have mine mounted on the window (center of dash) with the cord running down towards the driver's side footwell, then pulled through the center console and plugged into the rear cigarette lighter. Works perfect and easy to remove. It can be a bit more complicated depending on how long your cord is or how clean you want it. I ended up trying a few things and just found what I ended up liking as far as looks and what I thought was safe.
Old May 1, 2008 | 08:16 PM
Runmymouth's Avatar
I'm sad, my 3/4 inch mount was way too small. The stealth wire works like a champ though. If anyone wants some information ask and ill snap a few picks. Any other advice for ways to mount my radar detector above my mirror or from my mirror?
05rx8mazda
Nov 28, 2015 09:42 AM
ShellDude
Oct 1, 2015 09:55 PM
pjwermuth
Sep 28, 2015 11:36 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
