Well after 55k miles, problems.. :(
Old Apr 22, 2008 | 09:13 PM
mjones53's Avatar
After 55k trouble free miles, I'm having problems. No CEL but, down on power and missing a little. And, today for the 1st time it just died on me twice when it went to idle. Of course I had no problems until after the warranty expired 2 months ago.
So, I'm going to start by putting new coils, plugs and wires in her and hope that's all she needs since she has never had new ones.. also, wonder if it's just bad gas.
I could turn the air off and it seemed to be a little better.
'04 Yellow,6speed. No mods at all.
Well, she does have a K/N drop in filter, that I have cleaned just a couple weeks ago.
Anyone have any other ideas, please pass them along...
Thanks,
Old Apr 23, 2008 | 12:02 AM
Old Rotor's Avatar
Thanks,
Mazda has extended the warranty on your car to 5 years from the first purchase date or 60K miles which ever came first( when was it first purchased). Look at the first three "TSB's" and print out and take to your dealer.
http://www.finishlineperformance.com....php?pageid=11
Old Apr 23, 2008 | 11:19 AM
Cattywampus's Avatar
Turbos blow!!
I say new plugs, wires and a tune up should get you going. Are the plugs/wires the original ones?
Old Apr 23, 2008 | 11:22 AM
Red Devil's Avatar
Throttle body might have gone bad.
Old Apr 23, 2008 | 11:24 AM
Renesis07's Avatar
Vtak just kicked in yo!!
I had the same problems at 55k-60k. Ive replaced my cat, plugs, wires and Im runnin at full speed. I still havent changed the coils so I think thats whats causing the rough idle, or my CAI, one of the two
Old Apr 23, 2008 | 11:35 AM
SilverEIGHT's Avatar
At 58,000+, mine was doing the same thing. I had relatively new coils, plugs wires and the MAF had been cleaned. I took it in and came out with a new engine. Not saying that will be the issue with yours. Could be that replacing the things mentioned above would take care of it but you should take her in for the latest TSB.
You should read this entire thread: https://www.rx8club.com/rx-8-discussion-3/blown-engine-143463/
Old Apr 23, 2008 | 11:47 AM
Renesis07's Avatar
OP....Dont get yourself all twisting thinking you need a new engine. I do that **** to myself everytime I hear a wierd noise under my hood. You probably need an ignition tune up. Or just run a compression test. $100 is worth sleepin better at night right?
Old Apr 23, 2008 | 03:43 PM
mjones53's Avatar
well, took it into the stealership today, They said it needed plugs,coils,wires and the injections system cleaned. I let them do an oil change, and the injection cleaning an the new flash. I bought the plugs,coils and wires to do myself.So, far after that it is running worse than ever, dies every time now. I'll see how it is after the tune up.
Old Apr 23, 2008 | 03:58 PM
ken-x8's Avatar
Change the plugs first. You're well beyond their specified life span. Your symptoms are consistent with worn out plugs on any car.
I'm not surprised that the injection cleaning didn't help. IMHO, that's a big moneymaker for a (usually) nonexistent problem.
Ken
Old Apr 23, 2008 | 04:00 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
You're still under 60K, why didn't you let them do it?
Old Apr 23, 2008 | 05:33 PM
Raptor75's Avatar
This interesting this is about the 5th thread I have seen recently talking about engine failure between 50K to 65K miles. Could this be the sweet spot for engine failures, it will be interesting to watch. Maybe I'll start a survey on this.
Old Apr 23, 2008 | 05:53 PM
LionZoo's Avatar
road warrior
I'm thinking 50-65k is the sweet spot for coil failures.
Old Apr 23, 2008 | 06:25 PM
Its a sweet spot for new coils
Hell I replace mine every 15K miles :D
Old Apr 23, 2008 | 07:40 PM
... and me!
Old Apr 23, 2008 | 07:42 PM
LionZoo's Avatar
road warrior
And you wonder why you're broke...
Old Apr 23, 2008 | 07:59 PM
newcastle's Avatar
Carbon Fiber Roof
Wow! Original wires, plugs, and coils huh. More than likely that is the problem.
Old Apr 23, 2008 | 08:05 PM
kevinD1226's Avatar
u know what after the recent flash mazda has put out there my car is also running shittier than before... and the day before it got flashed i installed the mazsport ignition solution and it ran fine that whole day so i know its not that, after the dealer did the reflash it runs like ****, they also told me they do not recommend a de-carbonize on a rotary engine..
Old Apr 23, 2008 | 08:08 PM
newcastle's Avatar
Carbon Fiber Roof
ROFL
Old Apr 23, 2008 | 08:12 PM
kevinD1226's Avatar
lol i know man but thats what they told me cause i asked for it and they said it would be 129$ but their master tech doesnt recommend it on any rotary engine
Old Apr 23, 2008 | 08:17 PM
Red Devil's Avatar
Time for a new dealer.
Old Apr 23, 2008 | 08:18 PM
newcastle's Avatar
Carbon Fiber Roof
Show this to your tech.
http://www.finishlineperformance.com...14-08-1924.pdf
Old Apr 23, 2008 | 08:33 PM
Dominicano's Avatar
Im having a problem where when it gets way 2 hot or i've been runing the car for too long on a hot day the idle gets really rough and it may shut off...ill let is sit for a bit start it up and the car will start and will go back 2 normal..now the thing is currently im running the KN V2 would the dealer give me any crap if i go take it in for the tsb's?? It's an '04 and it has 46k miles.
Old Apr 23, 2008 | 09:10 PM
mjones53's Avatar
hold the phone, our cars have a 60k mile powertrain warranty?
did that cover plugs,coils and wires?
Old Apr 23, 2008 | 09:17 PM
mjones53's Avatar
I just found the letter I got from Mazda on the warranty being moved to 60/60000
how do I find out the "in service" date? I still think there is way more wrong that plugs. Thanks guys..
p.s I took a copy of both the re-flash and the other lack of power SB's and they barely looked at them. They did do the re-flash. But, did not see even hardly look at the other one. Guess, I'll be making another trip down to them after I change the plugs,coils and wires Friday. I really hope that is all it is.. the o'l girl has been amazing and not had any problems at all (knock on wood) hope this is not a sign of thing to come.
Old Apr 23, 2008 | 11:21 PM
Rootski's Avatar
DGAF
Check the catalytic convertor.
