Installation of Recaro sport seats
Old Apr 20, 2008 | 10:13 PM
rx8thunder's Avatar
Being (new) single rocks!
has anyone tried putting in Recaro seats like this...
http://www.stableenergies.com/prodin...mber=REC-SPEED
Do they fit ok? Does it give you a lower seating position than the OEM seats? Other seating options that offer more lateral support than OEM? Mostly for daily driving, not track. Thanks.
Old Apr 21, 2008 | 09:45 AM
heyarnold69's Avatar
Rotary wanabee
if you want seats like that .... why not just get the new 8 seats? when you add in the harness, mounting brackets, time and other needs, the price is close.
with the new rx8 recardo seats .... they are most likely bolt on and are 100% compatable and will fit right.
Old Apr 21, 2008 | 11:25 AM
rx8thunder's Avatar
Was thinking about that actually. Are they selling them now as an accessory now in NA? Have you seen pricing? Links? Thanks.
Old Apr 21, 2008 | 12:54 PM
staticlag's Avatar
The Professor
If its mostly for daily drive, then I would stick with the stock seats.
You realize if you switch the belts to harnesses your not going to be able to move in the seat, right? Can't reach glovebox, no reaching under seat, no reaching behind you.
Old Apr 21, 2008 | 01:16 PM
rx8thunder's Avatar
I would keep using the OEM seat belts. I'm just looking for a firmer and more bolstered seat like a Recaro provides -- like the new RX8 has. The 8 way adjustability of OEM is nice but I'm certainly willing to give that up for a better seat.
Old Apr 21, 2008 | 01:39 PM
savedsol's Avatar
Carbonormous
Me too - I'm not crazy about the drivers side support. Your issue will be the airbag light will be on from disconnecting the seat airbag.
The Mazda Recaros will probably be ridiculously expensive due to the side airbag. There would be no way to buy it without since it's sewn shut inside.
Old Apr 21, 2008 | 03:35 PM
rx8thunder's Avatar
Hmm... if that's the case, I would go aftermarket and get something that looks similar anyway. Curious as to weather anyone on the board has done this. Would like to know if it's difficult and whether the effective seat height is lowered vs OEM - I hope so.
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
