View Full Version : Loss of Power... which dealer
xsnipersgox
04-20-2008, 08:00 PM
long ass drive to campsite (1 hour) gas @ 1/2 tank, 93 gas, 4 oz premix idemitsu, then there was a part where i have to floor it and get up to speed. then i noticed that when i hit 7000 rpmish my engine dies, but i'll just shift to next gear and let the rpm drop, it will keep going fine.
then after i got home (Empty gas light on) i started to loose power at 3000,4000 rpm depending on if it was a hill/straigh, so i use the lower gear with clutch feathering while revving the engine at about 400 rpm to get home (mazda dealership close today)
i got to a gas station near home, went in, put in 2 gallons of gas(no premix this time, about 5 min of cooling down time for engine) and then on the way home (1mile) i was redlining it all the way... i manage to get to redline and stuff with regular power and no powerloss... wtf is going on, i am planning on taking it in tommorow morning and take the morning off.
where should i take it? and also.. does powertrain warranty cover rental?
Currently at Houston.
Keef
04-20-2008, 08:29 PM
Your first part sounds like what I've been getting for a while. If I execute a sharp turn, while flooring it. With the TCS, the engine for no some random reason shuts off for half a sec. I blame it on coils... You don't sound like you should worry that much. My car used to poor oil on start for a month, I worried then for a reason...
05rx8mazda
04-22-2008, 02:47 PM
take it to roger beasly mazda.. they have taken care of me for the lognest time!
Talk to Matt Hes the one ive trusted as my advisor.. Be like the guy with the white mazda referred me to you =D
hell know who i am lol..
Ive had many many issues with my car the first two years =D
05rx8mazda
04-22-2008, 02:48 PM
ohh nevermind your in houston.. idk that turf
Geforce07
04-24-2008, 10:07 PM
Hey dude, I just brought my car into Mazda today and they did a recall on my computers. The recall is because rx8 owners complain about power loss so the reprogram is suppose to spit more oil into the engine? I dont know but after it was done, my car kept dying on idle speeds. If my foot isnt on the gas, the car will shut off. At a red light, my car stalls completely. I quickly U-turned and brought it to the dealer to have them look at it and they gave me a rental car. I dont know whats up?
rowteree
04-24-2008, 10:38 PM
i have the same problem with my car every time i reset the computer or disconnect the battery terminals. It doesnt want to idle and at stop light it dies on me. My foot isnt even on the gas and the car will shut off, but it goes away after 20 miles down the road??? :Eyecrazy: Let me know what the dealer tells you Geforce
Geforce07
04-24-2008, 10:41 PM
Will do rowteree, long time no see btw ehe. Whens the next meet? I need to start going again. I got a Dodge avenger as a rental and dude that thing sucks! I didnt want to drive it so my friend drove me to work today..haha
05rx8mazda
04-26-2008, 03:16 PM
hey thast much better than my kia hahahahhaha
sometimes the dealer gives me the suv whats it called ummmm its the mazda suv i dont remember the name i kinda liked it..
ive gotten the mazda 6 wagon now that thing is huge!
Geforce07
04-26-2008, 04:40 PM
This car smells like heavy smoke though =(
rev44
04-26-2008, 06:13 PM
Jeff Haas Mazda
Good luck and keep us posted
Nichiren
04-27-2008, 02:47 AM
Hmm...that's weird i had my car reflashed 4-18-08. hadn't had a problem yet. do you two have any after market parts? The only thing that may affect the Ideling is the RB revi intake and duc. I also using RP 5-20. Let me know what the dealer says.
Geforce07
04-27-2008, 02:58 AM
I do not have any aftermarket parts other then KN drop in filter and I use RP 5W30. My car is still in the service department
Geforce07
04-28-2008, 02:34 PM
At the moment, the dealer is planning on replacing my engine...
Geforce07
04-28-2008, 05:04 PM
Alright so I just got a call today and they said my battery was loose and I need to replace my engine mounts, which they did for me for free. They said everything is running fine now. I do have a aftermarket battery but I didnt think it was loose and would cause my engine to die. This happens right after they serviced my car so they're probably bsing but as long as its working. Also said my clutch needs to be replaced, its been around 47,000 miles. Is this too soon to replace the clutch?
Nichiren
04-29-2008, 10:12 AM
That sound a bit fishy, which dealer did you go to again? I'm at 42 k , hadn't had a problem with the clutch yet. But hey if it's under warranty get it done.
xsnipersgox
04-29-2008, 07:14 PM
wats funny is that my problem is still here after replacing 2 leading plugs, i need to order 2 trailing plugs. -.-
Nichiren
04-29-2008, 10:03 PM
never mind
Geforce07
04-29-2008, 11:39 PM
Well I got my car back today and they adjusted the battery and replaced my engine mounts under warranty. My car is now fixed and is running wayyyy better then before. My car is now 10x smoother on idle and everything else. Feels like the car isnt even on. This is prob cause of the new engine mounts but everything is fine now
Nichiren
04-30-2008, 02:09 AM
Geforce that's good to hear. hope sniper has the same luck with his car. Will you guy be at the Tuesday meet (5-6-08) ?
S-AIR
07-23-2008, 10:19 PM
sounds like the catalytic convertor if it is stalling beyond 5k rpm....
Not sure can someone confirm?
rowteree
07-24-2008, 12:40 AM
sounds like carbon build up in the engine. Failed catalytic converter anyone?
Brazuka
08-06-2008, 08:22 AM
I've had the same problem where the engine will run fine until you've been on the road for about 15 mins or so, then it will keep speeds on straights but looses power on hills. I took to Mazda they blamed the O2 sensor and the battery. The battery is CCA at 530, it is only 10 months old. The O2 sensor doesn't seem to be damaged, but I am not sure. I took to Donald Craig Mazda in Mooresville, NC. I don't like them, I don't trust them. As a matter of fact I took the car in with engine light blinking. Picked up with ABS DSC and Brake lights on as well. Noticed a missing fuse. Why would they play with that? Poor service.
Anyway, I think my catalytic converter is either gone or about gone and it is plugging the engine. The catalytic converter is extremely hot, more than normal, to the point it burnt some electrical tape around wires that are 8" away from it. Going to take a Meineke to get a different opinion.
Let me know if you have any more useful information.
Uncivilizedracer
08-06-2008, 01:13 PM
Mine does the same sh!t i need to take some time and take it to the dealer to get this looked at , keep me posted
O-M-D
08-25-2008, 09:07 PM
which dealer did geforce took the car too cuz it seems
I'm having the same problem
O-M-D
08-25-2008, 09:30 PM
I'm having the same problem as geforce the light blinking
and it reads cylinder 2 misfire so I need to now whats the
best dealer in Houston that can help with out them liying
to me I call mazda of north America and they told me that
there has not been a recall about whats happenig to my
car so they told me that I was in my own. I like the the car
but I'm having second toughts about then motor.
HeavyMetal699
08-25-2008, 09:37 PM
Munday Mazda isn't too bad. If they find the problem they will try real hard to fix it.
Unfortunately you have to SHOW them the problem. If they don't acknowledge it in the car with you don't even drop it off.
yokohamaboi
08-26-2008, 09:09 PM
We have cylinders? lol well idk but i dont feel any power in my car, only has 5600 miles on it, already got the MSP16 reflash and it feels slow, when i punch it, it takes to long to go fast :[ poor throttle response. :banghead:
thejew89
08-26-2008, 11:21 PM
mines starting to sputter around 6k rpm once its warmed up but no CEL what does this sound like to everyone? im gonna bring it in on thursday cuz im off work and see what mazda has to say about it.
