fogged out taillight
Old Apr 19, 2008 | 11:49 AM
Leaveitstock's Avatar
am i the only one that has the problem with a fogged out taillight ive gone through 3 different driver side taillights and the just keep foggin up on me. the dealership tells me that its cosmetic and that its not covered. anyone else have a clue what to do
Old Apr 19, 2008 | 12:10 PM
KateM's Avatar
Mine did that when I first bought the car. They fixed it under warranty. It was a long time ago though, so I forget what the actual problem was.
Old Apr 19, 2008 | 12:13 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
There is a TSB on it, go search for "water in tail light" or go to http://www.finishlineperformance.com....php?pageid=11
It a common issue and they should take a care of it. It involves replacing the gasket.
You can alkso search the issues and problems and/or the DIY section if you want to do it yourself.
Old Apr 19, 2008 | 03:22 PM
LiL BenNy's Avatar
Bubblicious? DEF.
that tbs is only if the car is still under warrenty correct?
Old Apr 19, 2008 | 03:42 PM
yeah but it has to be something on my car not the light because ive replace the light 3 times and it wouldnt be 3 bad lights
Old Apr 19, 2008 | 03:57 PM
chrism's Avatar
Misfit Moderator TnC
i have replaced it 5 times.....your dealer is a liar......i am sorry but if you are under warantee take it to a competant dealer, have them perform the proper tsb, sue the proper gasket and it shouldnt happen again.....and try searching before hitting the start new thread button.....you might wanna refrain from riling up the walnuts
Old Apr 19, 2008 | 06:45 PM
midlifer's Avatar
chrism is right, take it to another dealer. My service dept. keeps them in stock because of the issue. I had my passenger side one replaced last week.
Bob
Old Apr 19, 2008 | 06:51 PM
05rex8's Avatar
sold the 8... :(
i just took my taillights out myself (very easy) and drilled 2 small holes underneath the taillights. I should take pictures..... It allows air to recirculate. Mine haven't fogged or gotten water in them for a few months now.
Old Apr 25, 2008 | 09:57 AM
well i took it to the dealership again the same one that turned me down the first time and they explained it to me like this... they would call it in but they're sure its not covered under warranty cause its a gasket that goes around the bulb not the actual plastic casing. but i saved myself some time and listened to 05rex8 and just drilled two small holes around the corner where the water was gathering. it hasnt fogged up yet.
Old Apr 25, 2008 | 10:14 AM
m3pkrobert's Avatar
i had the same problem on my 8 and i did a little hole in the bottom of the light and drain the water now when its rain get water but after 3 sunny days the water is gone
Old Apr 25, 2008 | 12:44 PM
nmarz77's Avatar
I drilled a 3 small holes myself and I never get any water accumulation or fogging anymore rain or shine.
Old Apr 25, 2008 | 01:54 PM
Socket7's Avatar
ಠ_ಠ
There is a how-to make and install a better tail light gasket in the DIY section if you are out of warranty. No hole drilling required.
If you have standing water in your light, they will replace it under warranty. People with just condensation may run into "no thats not covered" crap
Old Apr 25, 2008 | 03:38 PM
yea ill just put my old tail light back on let it gather some water and take it to a different dealership cause when the water sits in there it starts deteriating the reflective plastics
Old Apr 25, 2008 | 03:44 PM
Zuhalter Vati's Avatar
My dealership replaced both driver and passenger side without any questions. There are several posts about it...there might even be a recall out there.
Old Apr 25, 2008 | 03:55 PM
dont mean to be personal or anything but which dealership like just a straight mazda dealer or something else too. cause the only one within 10 miles of me is a Chevy dealer but they have a small mazda section and they have been pretty good at everything else but they wont even talk to me about this tail light.
Old Apr 25, 2008 | 05:15 PM
nuke0907's Avatar
Never Blend In
i had standing water in mine and i just got a new gasket off of finishlineperformance.com. i drained all the water out and switched the gasket out and its as good as new except the reflective film came off a bit inside from the water. if you only drilled holes, the water is still gonna get in and mess up the inside.
Old Apr 25, 2008 | 06:34 PM
05rex8's Avatar
sold the 8... :(
^^like i said b4 i only drilled holes and i never get water or condensation rain or shine. maybe my gaskets were replaced b4 from the previous owner
Old Apr 28, 2008 | 05:17 PM
nmarz77's Avatar
It's been raining here all day and no water or fogging seen in mine with drilled holes.
Old Apr 28, 2008 | 05:34 PM
9G Redline's Avatar
Trolling since 2004
I just sucked it up and bought a new gasket from the dealer for $60 freakin' bucks. It's now fixed but, unfortunately I have water spots inside the cover...wtf!? So irritating!
Old Apr 28, 2008 | 06:23 PM
LiL BenNy's Avatar
Bubblicious? DEF.
i just drilled holes aswell... found that the reflective paint was pealing... can i bake them and respray them? or anyone know how to fix them?
Old Apr 28, 2008 | 06:25 PM
LiL BenNy's Avatar
Bubblicious? DEF.
scratched that it rained today and just checked... still fogging...
Old Apr 28, 2008 | 07:38 PM
yelloRx8's Avatar
A taste of Italy
yea both the tail lights on my 8 do the same thing...if anyone knows how to remove the tail lights let me kno how cuz just by lookin at it i cant figure it out and dont wanna break anything
Old Apr 28, 2008 | 08:11 PM
nuke0907's Avatar
Never Blend In
one of the dealers here told me that same price. i told them i seen them online for around $35 and they said to bring them a printout and they'd match it. i just said screw that and ordered them online. go to finishlineperformance.com to pick some up. if you also look at the TSB, if there is water spotting inside the lense the dealer is supposed to replace the whole assembly under warranty. if you're out of warranty you're kinda screwed.
from inside your trunk, pry back the carpet liner in the corner. disconnect the bulbs and sockets. then just remove the 2 nuts holding it in. be careful not to drop it. make sure to get all the moisture out and swap the gaskets. should be fine after that. i have more pics if anyone is interested in the process.
vapor2
May 4, 2020 03:53 AM
RXFEVER
Aug 29, 2018 10:14 AM
yurcivicsux
192
Sep 12, 2017 10:54 PM
RXFEVER
Sep 11, 2016 02:51 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
