Electronic LED Flashers - which of these would I need?
Old Apr 15, 2008 | 08:42 PM
TeeFar's Avatar
for my signal lights
http://www.v-leds.com/Shop/Control/f...m/1/menu_num/3
Old Apr 15, 2008 | 08:49 PM
SoopaDoopa's Avatar
ARE-ECKZ-ATE
You talking about strobes more or less in your turn signals?
Old Apr 15, 2008 | 08:54 PM
TeeFar's Avatar
less in my turn signals, so I don't have to deal with load resistors.
Old Apr 15, 2008 | 11:08 PM
nuke0907's Avatar
Never Blend In
why don't you just get stealth bulbs? they look better anyways. or the PIAA mirror orange bulbs like i have. they look really nice.
Old Apr 16, 2008 | 07:28 AM
TeeFar's Avatar
because I want LED's...
Old Apr 16, 2008 | 08:05 AM
Spin9k's Avatar
Momentum Keeps Me Going
To tell which is correct, you'd need to remove the flasher unit from the car, compare it's pins to one that might match up. I've never heard of a direct replacement but perhaps someone has found one. Using resistors is a bit of a pain, but nothing hard, and works fine.
Old Apr 16, 2008 | 09:52 AM
SoopaDoopa's Avatar
ARE-ECKZ-ATE
I had strobes in the corners of my old whip. I didn't even bother trying to install them. My computer nerd buddy did all the work.
Old Apr 16, 2008 | 03:33 PM
c41250n's Avatar
where you got the piaa bulbs from?
Old Sep 5, 2008 | 03:17 PM
TeeFar's Avatar
still no answer to this question???
Which one of these electronic flashers work in the 8. I just want to add LED's in my signals/flashers.
Old Sep 5, 2008 | 04:45 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Those won't work. The rx8 has a flasher control module. I was able to reprogram the module to work with LED turn signals.
Old Sep 5, 2008 | 06:40 PM
Conundrum's Avatar
Is that difficult to do? as in a lot of equipment and skill involved, or basic tools would do
Old Sep 9, 2008 | 02:01 PM
It wasn't hard. I figured it out within an hour. All you need to do is change the variables that control the 556 timer. (i.e., caps and/or resistors)
Old Sep 9, 2008 | 03:12 PM
NgoRX8's Avatar
if you aren't as knowledgeable with this as RR (lol!), just wire a resistor at each turn signal. I bought load resistors, but they were a few bucks a pop. turn signals are still working well so i'm happy.
Old Sep 10, 2008 | 12:59 AM
Yea, that works too. It defeats the energy saving advantage of LEDs but it's sure a lot easier.
Load resistors get hot, keep that in mind when mounting them.
Old Sep 10, 2008 | 05:38 AM
Spin9k's Avatar
TeeFar, check out this thread for some pics and description that should help you do this with resistors.
https://www.rx8club.com/showthread.p...ight=resistors
Old Sep 10, 2008 | 05:47 AM
Eight's Avatar
Had load resistors on my old car, left the car on the side of the road with the turn signal on for a while and came back to smell burnt plastic it melted the plastic panel which I mounted the resistor to...
Old Sep 10, 2008 | 05:49 AM
Spin9k's Avatar
good lesson learned there...glad it didn't torch your car
Follow the directions/pics in the link above to do it right.
Old Sep 10, 2008 | 10:35 AM
Tamas's Avatar
Registered Lunatic
Rodger, any chance for a DIY?
Old Sep 10, 2008 | 10:45 AM
Tamas's Avatar
Registered Lunatic
You can even build your own load equalizers using wirewound resistors available at Radio Shack (that's what I did and they work fine). However you only save a couple of bucks this way, so I'm not sure it's worth the effort - it doesn't cost too much more to just buy the load equalizers and be done with it.
As it was said, the resistors get quite hot, so make sure you safely mount them to a metal surface that will act as a heat sink.
Old Sep 10, 2008 | 12:12 PM
NgoRX8's Avatar
lol, rodger doesn't have a car anymore to do a DIY on.....
Old Sep 10, 2008 | 12:29 PM
this is true....
I think I have an extra module somewhere. I was in the process on making a kit for people. I'll have to look.
I'll snap a photo if I find it.
Old Nov 24, 2008 | 12:39 AM
Saylord's Avatar
Hrm, im looking at a wiring diagram of flasher control module and inputs D (left turn signal) and G (right turn signal). Do I put a resistor at each of these inputs? You said caps, that is not ringing any bells with me, course it is late and im tired =p maybe capacitor. What is best to do? Sometime in the future im going to hook up LED's and was just curious how this is done instead of putting resistors at the light location.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
RX8mzda
Oct 14, 2015 05:12 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
