Adding MS lowring springs to Shinka
Old Apr 14, 2008 | 05:29 PM
xone2001's Avatar
I just recently purchased an 05 Shinka with only 17k miles on it!
I was thinking about installing the MazdaSpeed lowering springs but was not sure how that would work with the suspension tuning that was done to the 05 Shinka. I've gone over a few threads regarding suspension but nothing in regards to the 05 Shinka.
Anyone have any input on this?
Any information would be greatly appreciated.
Thanks in advance!
Old Apr 14, 2008 | 06:36 PM
Jasonawojo's Avatar
Definitely can. Generally with those springs the Mazdaspeed (or other aftermarket) shocks are recommended as the stock shocks will wear out much quicker. Not sure if the special Shinka shocks would be sufficient..
Old Apr 14, 2008 | 06:53 PM
restiller's Avatar
sofa king
good question.
I'd assume the stock shinka shocks would suffice, since the shafts are 2mm beefier in diameter than on the normal rx8 shocks. I plan to use Eibachs with my stock shocks after my warranty is up.
Old Apr 15, 2008 | 09:01 AM
xone2001's Avatar
Thanks for the quick responces!
I'm going to do a little more research but I think i'm going to go forward with this. I'll post some before and after pics.
Thanks again!!!!
92trbolzr
May 18, 2025 09:04 AM
mdl0209
May 23, 2019 05:46 PM
duworm
Oct 1, 2015 04:57 PM
Tgiolitto100
Sep 29, 2015 10:52 AM
