View Full Version : Can someone help: 19s or 18s???
CraigRX8 04-11-2008, 04:09 AM I cant find a definitive answer on this.
19s look the dogs balls but will they kill the handling, acceleration??
i would be looking at te37s
RX8Maine 04-11-2008, 07:15 AM The only reason to drop change on TE37's is for track duty. For the best handling on the track, and cheaper track tires, consider 17".
I suspect this is more of a cosmetic purchase, however, so go for the 19". Yes, it will be harsh with less overall grip, but probably will have better initial responsiveness.
Spinning Sushi 04-11-2008, 07:22 AM You should do chromed 22's and get the 22'' badging for your car.
That will look dope.
HiTMaNN 04-11-2008, 06:20 PM You should do chromed 22's and get the 22'' badging for your car.
DubZ (with a Z) FTMFW
LionZoo 04-11-2008, 06:24 PM The only reason to drop change on TE37's is for track duty. For the best handling on the track, and cheaper track tires, consider 17".
I think you'll find most people that get the TE37s do it for the blingy "I'm a balla with Volks" effect.
For a complete answer, what exactly do you plan to do with your car? Additionally, how are the roads in your area?
bruce_van 04-12-2008, 12:04 AM If you can afford lightweight 19"s, then go for it. They definitely look better than 18"s.
That was easy.....and no sarcasm.
imput1234 04-12-2008, 12:14 AM Go with 18's, if your worried about performance. You should notice a huge improvement if you go from OEM to TE-37s in 18's, they are forged and light. Heck even the TE's in 19's are 2lbs lighter than OEM.
swoope 04-12-2008, 12:37 AM less is more.
beers :beer:
CraigRX8 04-12-2008, 01:57 AM Roads are pretty bad to be honest.
Im not building a track car. Its a daily driver but i enjoy taking it out on the country roads and giving it a good thrashing. Dont want to wreck that.
Rotary__Rocket 04-12-2008, 02:02 AM Go with 18's, if your worried about performance. You should notice a huge improvement if you go from OEM to TE-37s in 18's, they are forged and light. Heck even the TE's in 19's are 2lbs lighter than OEM.
very true indeed
go wider too~~~
Fortunate Few 04-12-2008, 03:21 AM the new 8's come with 19s you should take that into consideration. if its good enough for an 09 then its good enough for your car.
Flashwing 04-12-2008, 03:24 AM If you really want to know, go find your favorite set of tires and check the 18's and 19's prices on them. If you don't cry, go with the 19's.
LionZoo 04-13-2008, 01:29 PM Roads are pretty bad to be honest.
If the roads are pretty bad, how will you feel about bending a Volk rim?
Dinhx8 04-15-2008, 10:45 AM if the roads are bad, you can bend any wheel, any size.. its not as if a huge pothole won't hurt a 18 inch wheel. Yes an 18 inch wheel wil have more rubber and a higher profile most likely but the point is if you're buying pricey new wheels be careful regardless of size of road hazards.
i had a tough time also deciding between 18 and 19s. All the pros about 18s are totally legitimate, but as most have said it depends on what your preferences are.
I went with 19s, on a daily driver in DC and the roads suck. I went with lightweight 19s (lighter than oem ) and invested in good tires (michelin ps2) to sort of find a happy medium.
While 18s may have given me an edge performance wise, the style of 19s I prefer so i did my best to try to make up the performance difference by getting good tires and a light 19'' wheel.
SoopaDoopa 04-17-2008, 10:43 PM You should do chromed 22's and get the 22'' badging for your car.
Why not raise your ride nine feet in the air and go with 24's. That'd be fly.
