Can I mix oil? Need answers ASAP!!
Old Apr 6, 2008 | 02:04 PM
Falken's Avatar
Drop it into 3rd
(answered, thank you all)
I just bought my RX-8, it's half full of oil, and I don't know what kind. It's getting low, will it cause problems to put a probably different type of oil in the pan? If not, what kind should I use?
PLEASE DON'T TELL ME TO SEARCH OR CHECK MY MANUAL. I've tried, it doesn't work, and in the time it takes you to type your stupid immature comment you could have answered my question.
Thanks,
-Falken
Old Apr 6, 2008 | 02:06 PM
mysql's Avatar
Doppelgänger
mix and match. The car won't mind.
Old Apr 6, 2008 | 02:07 PM
Oil is compatible, essentially you can mix in pretty much anything...For now put in some 5-20, or 5-30 Castrol GTX...and then you decide what you want to do for oil at your next oil change
Old Apr 6, 2008 | 02:11 PM
Falken's Avatar
Drop it into 3rd
Thank you so much! What oil should I use? (I know almost nothing about this)
And where the heck is the dipstick??
Old Apr 6, 2008 | 02:13 PM
Try The Castrol 5-20..it's easier til you figure a bunch of other stuff out...
The dipstick is on the drivers side of the engine...close to the firewall
Old Apr 6, 2008 | 02:27 PM
mysql's Avatar
Doppelgänger
take off the engine cover for a better look.
Old Apr 6, 2008 | 02:28 PM
GULAMAN's Avatar
how do you know 'it's half full of oil' and 'getting low' if you don't already know where the dipstick is????
did a light come on?
Old Apr 6, 2008 | 02:41 PM
j67345's Avatar
I was thinking the same thing
Old Apr 6, 2008 | 02:47 PM
Rootski's Avatar
DGAF
Dude's kinda moody....
Old Apr 6, 2008 | 02:51 PM
4me2's Avatar
distiled water works the best. No , vinegar tastes the best.
Old Apr 6, 2008 | 04:01 PM
Socket7's Avatar
ಠ_ಠ
I'm gonna give these ones to you. You'll notice the recommended oil weight is located on the oil cap itself (GF-3 5W-20). Theres a cover over both of these things so they can be hard to spot at first. As a jet engine mechanic, I'm sure you don't need be shown how to use the dipstick too, right?
Old Apr 6, 2008 | 04:05 PM
Conundrum's Avatar
How are you guys getting a better read of the dip stick?
My dip stick has the marking and everything, but the oil is barely sticking on to the dip stick to get a good read of where oil is at full or low.
Old Apr 6, 2008 | 04:08 PM
Socket7's Avatar
ಠ_ಠ
I've got a little LED flashlight on my keychain that I use to help spot the film.
Old Apr 6, 2008 | 04:14 PM
expo1's Avatar
He's as bad as Can
I think he got that idea from the oil gauge.
"Seeing as how he specifically stated he filled the oil I assumed he had. The oil gauge reads a hair above half right now, is that enough??
Old Apr 6, 2008 | 04:16 PM
expo1's Avatar
He's as bad as Can
I put two holes in my dipstick.
Old Apr 6, 2008 | 04:56 PM
CyberPitz's Avatar
Huge hole is huge
That's a nifty Idea. What I do, is shine it at the sun, then use my finger to make sure there is a liberal amount of oil on that part of the stick. Works for me!
New Yorker's Avatar
Sometimes people change the kind of oil they use on purpose (they want to switch to a different grade, or to synthetic, etc.); since a routine RX-8 oil change leaves some of the old oil in the system, mixing oil is apparently no big deal.
Old Apr 6, 2008 | 09:50 PM
Falken's Avatar
Drop it into 3rd
There ya go! Damn, some people.
Yes, I know how to work a dipstick, I eventually found it myself. I simply left this thread because I had to leave to go help my friend film something (thus we have the ASAP in the title, I didn't want to go anywhere on an unoiled car) and since than I have been just about everywhere in the city.
Old Apr 6, 2008 | 11:26 PM
fourflush's Avatar
There is no oil gauge. I'm hoping this is a joke, oil pressure gauge, which i guess could tell you that your really low on oil.
Old Apr 6, 2008 | 11:37 PM
Spinning Sushi's Avatar
I <3 Sushi
Thanks,
-Falken
I will be the ******* to say this.
SEARCH!
Old Apr 6, 2008 | 11:45 PM
StealthTL's Avatar
Metatron
Come on FalkenDude - you still have to 'fess up as to how you thought it was 'half full'....!
S
Old Apr 7, 2008 | 12:17 AM
GULAMAN's Avatar
I have a feeling this thread will soon make it onto the HoF list. too funny.
Old Apr 7, 2008 | 02:55 AM
liam's Avatar
Ahhhh..... the irony I read here at the RX8 forum. A guy who calls himself the "DIY Jet Engine" guy can't even figure out a simple car engine.
Old Apr 7, 2008 | 04:07 AM
Wind Dance's Avatar
Central Valley RX8
ROFL Come on guys he's light years ahead of use rotary guys.. I mean they did stop using rotaries in planes.
Old Apr 7, 2008 | 07:44 AM
Falken's Avatar
Drop it into 3rd
Wow the stupidity I read here at the RX-8 forum. To be honest, I don't know much about car engines at all but if you would like a look at my jet engines feel free to check these links.
http://www.putfile.com/pic/5204222?pos=top The entire unit. The turbo spools up compressing air, putting it into a combustion chamber where a flame tube with precisely measured holes slows the air and lets it inside of itself, there it is mixed with fuel, lit, and blasted into the turbine wheel of the turbocharger for 20lbs thrust. I'm working on a larger one right now.
http://www.putfile.com/pic/5204233 I used a small turbocharger as the compressor/turbine.
http://www.putfile.com/pic/5204231 The ignition key is as of now totally miswired, I have to manually turn the distributor.
http://www.putfile.com/pic/5204232?pos=top The center hole is for kerosene, the left hole is for a high energy spark plug.
http://www.putfile.com/pic/5204228?pos=top A look down the tailpipe at the turbine wheel.
http://www.putfile.com/pic/5204226?pos=top The combustion chamber/flame tube's outlet into the turbine wheel.
http://www.putfile.com/pic/5204227?pos=top The turbo that is the heart of my engine.
http://www.putfile.com/pic/5204224?pos=top You can see the air outlet into the combustion chamber here.
http://www.putfile.com/pic/5204225?pos=top Another combustion chamber shot
Suck it, jerk
