REV Limiter
Old Apr 4, 2008 | 10:44 PM
mazdatim's Avatar
REV Limiter
How can you change the rev limiter to a slighter higher rev limit , without buying an expensive unit to do so. Thanks, mazdatim
Old Apr 4, 2008 | 10:46 PM
Spinning Sushi's Avatar
I <3 Sushi
Old Apr 4, 2008 | 10:57 PM
racing beat flash does this: $300
AP can do it: $700
Old Apr 4, 2008 | 11:59 PM
HiTMaNN's Avatar
RX-8s Official Cool Guy
Why would you want rev higher?
Old Apr 5, 2008 | 12:57 AM
turborx8's Avatar
Boost 4 Life
So that you can make less power. Duh!
Old Apr 5, 2008 | 10:24 AM
HiTMaNN's Avatar
Duh! Cause the equation is Heavy Foot + +9K Rpm = More Power? COME ON Get with the times...
Old Apr 5, 2008 | 11:25 AM
zoom44's Avatar
because Hitman- as has been shown with the racing beat flash- if the car is tuned right then raising the rev limiter helps make more power AND allows you to shift later staying higher in the power band when shifting.
sidebar: i couldnt open this on my pc because i dont have excel here. so i uploaded it to google spreadsheets and published it so i can share it.
the spread sheet shows that 9000 on the RBflash im still making more power than i was at 8000 stock. Its actually the same as at 8100 stock
http://spreadsheets.google.com/pub?k...wcd2tPD3yASFWA
Old Apr 5, 2008 | 11:42 AM
HiTMaNN's Avatar
Warranted zoom but that is beacuse RB spent some time on there tune and made other adjustments then just making your engine rev higher..... BUT Just raising the Rev Limiter, like the OP asked, does not mean that you will get more power.
Old Apr 5, 2008 | 12:15 PM
zoom44's Avatar
correct
Old Apr 14, 2008 | 01:26 PM
tbonespeed12's Avatar
what is the max safe rpm you could run the engine it? the guy i got mine from had a catback and a rb intake. He said he did something with the computer but idk what he did! ive taken it to 9.5k before and he says the limmiter is at 10k! so should i shift at 9k-9.2k from now on?
Old Apr 14, 2008 | 02:04 PM
kristopher_d's Avatar
Drive Master
Your shift point will depend on how fast you're going (assuming WOT). At slower speeds, you want to try to land the rev's at 5500 for best Torque. As your speed goes up you need more HP just to keep moving, so you need to shift later and have the rev's land higher. It's an odd bit of aerodynamics and engine dynamics crossing each other. A higher rev limit may be nice for running the engine out a bit more going into or coming out of a corner, and being lazy on your shifts, but it certainly doesn't have any direct performance benefit.
The engine is harmonically sound to somewhere upwards of 12.5K RPM. However, there is a lot of stuff attached to the engine that would complain terribly, and throw a nasty tantrum, if you did that. 10K is pushing the limits of safety.
Old Apr 14, 2008 | 03:43 PM
tiltmode43's Avatar
OMGITM!
Sorry for off topic but dammit Zoom, you're making my rb flash V accessport debate more and more difficult. I tend to trust RB more due to a relatively conservative (and lengthy!) history but the Accessport's ability to save/reflash is luring me.
Though the difference is 9.5 hub the powerband in general is really making it hard for me not to head over to racing beat and get the flash.
So, Accesport for $700 with custom maps from MM
or
RB *conservative* flash for $300 + $30 OBDII scanner and hopes of nothing going wrong with my car thus calling for dealer/reflashing...
The shifting/torque debate is one to hold great validity. One reason I love the renny is we get to shift up high and make power as opposed to low revving high torquing engines. Also, regardless of where we make most power, revving to the heavens is always fun...
Old Apr 14, 2008 | 05:06 PM
rotarenvy's Avatar
everyone talks of raising the rev limiter but can the flash devices lower it? say down to 8000-8500rpm?
Old Apr 14, 2008 | 05:12 PM
tiltmode43's Avatar
OMGITM!
I'm certain MazdaManiac Jeff can lower it through accessport...
Old Apr 14, 2008 | 05:54 PM
r0tor's Avatar
be careful what you ask for... it might come true
damn aspl0ding flywheels and clutches...
Old Apr 21, 2008 | 05:59 PM
cheeto's Avatar
has money, but unsure
mazda recommends that the flywheel never surpasses 10k rpm
Old Apr 21, 2008 | 06:01 PM
r0tor: that's creepy
Old Apr 21, 2008 | 06:03 PM
I <3 Sushi
Lulz, SRT-4 pwnage...
Old Apr 24, 2008 | 09:39 PM
Of course you can lower it.
Hunterkelley24
Jun 14, 2022 08:32 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
garryg
Australia/New Zealand Forum
Oct 1, 2015 04:54 PM
RAVSPEC
Vendor Classifieds
Oct 1, 2015 01:59 PM
Jb4ker96
Sep 27, 2015 10:06 PM
