Bumber removal for headlight access?
Old Apr 4, 2008 | 05:15 PM
carkid's Avatar
young and obsessed
I just ordered a visionpro HID conversion kit without knowing that i would have to remove the bumper. Is this easy to do?? the website and the instructions make it sound very easy but if someone has any experience doing this please help me out thanks.
Old Apr 4, 2008 | 05:26 PM
expo1's Avatar
He's as bad as Can
Its not too hard, taking the connectors off the fog lights is the biggest pain. Skillful use of a long, thin screwdriver help with that.
File Type: pdf
Old Apr 4, 2008 | 05:29 PM
JRichter's Avatar
Void Where Prohibited
As far as removing the bumper it's just snaps and bolts that are all fairly accessible. The snaps for the fog harness can be a bitch to reach. Might be a little easier if the front is jacked up a hair to reach the underneath ones but is not necessary if your car is at stock height. Doesn't take long at all if you have paperwork pointing out the bolt locations. I think it took me like a half hour tops to remove and replace when I installed my oil-cooler screens. You'll need a flathead and phillips head (for the snaps) and the appropriate socket (for the bolts). When you go to put it back on you may want someone to help you hold it to line up properly.
Old Apr 4, 2008 | 05:35 PM
carkid's Avatar
young and obsessed
i dont have fog lights, so it shouldnt be hard huh, how long do you guys think this will take (2 people both have no idea what they're doing) im just worried im not gonna be able to put the bumper back on and be screwed
Old Apr 4, 2008 | 05:38 PM
CTrx8's Avatar
space for rent
the bumper even for an unexperience person can be done in about 20 minutes while drinking
Old Apr 4, 2008 | 05:43 PM
carkid's Avatar
young and obsessed
does anyone have any experience with a HID conversion kit? now that i know it's easy to take the bumper off. thats half the problem dealt with.
Old Apr 5, 2008 | 10:11 AM
carkid's Avatar
young and obsessed
before i go to auto zone can anyone tell me the exact tools i will need to take this bumper on and off? and anything else i might need to screw around with my headlights?
Old Apr 5, 2008 | 10:59 AM
CTrx8's Avatar
space for rent
https://www.rx8club.com/showthread.php?t=10941.html
EDIT: actually, expo already posted a very good pdf that shows what you'll need to do. it's all basic tools.
Old Apr 5, 2008 | 11:09 AM
I8U's Avatar
I8U
I have an HID conversion kit...didn't have to take the bumper off either. I just installed everything thru the fender well. As far as the kit itself, it's a matter of connecting a couple wire harnesses and and mounting the ballast securely to the vehicle.
Old Apr 5, 2008 | 11:47 AM
carkid's Avatar
young and obsessed
thanks a lot guys i really appreciate it
Old Apr 5, 2008 | 03:01 PM
mikeferrell's Avatar
I removed my front bumper when installing the HID kit just so i could mount the ballast right behind the bumper when i put it back on so it would have the least possibility of contact with water. plus the ballast fit perfectly there.
Old Apr 6, 2008 | 11:10 AM
carkid's Avatar
young and obsessed
ok i managed to install the HID's with LOTS of help from I8U, thanks man, but, my headlights are definitely not aligned properly, my left one seems a bit bright and aiming down a bit
and the right one is aiming all the way down. How do i fix this, isnt there a shop manual that says theres a way to adjust them up and down with a screwdriver?
Old Apr 6, 2008 | 11:12 AM
carkid's Avatar
young and obsessed
and i mounted the ballasts behind the corner lights and a little bit above them, is that ok?
Shankapotamus3
Mar 14, 2021 03:53 PM
Digitz0070
Oct 7, 2015 12:43 PM
Learners_Permit
Sep 27, 2015 07:38 PM
drlubell
Sep 26, 2015 11:58 PM
