FS Megan Racing Coilovers (used)
Old Apr 4, 2008 | 06:36 AM
Beeotch's Avatar
I have a set of megan coilovers used only 3k miles. The reason why im selling these is because last night I hit a curb and my Mazdaspeed front bumper cracked and now I have to get a new one. Note that these coilovers were never installed on my car so it was not damaged in the accident. I paid $740 for these from a friend so im looking for $600 shipped.
Old Apr 4, 2008 | 07:40 AM
dytrd5's Avatar
pm'ed
Old Apr 4, 2008 | 09:15 AM
Beeotch's Avatar
replied
Old Apr 4, 2008 | 02:40 PM
nmarz77's Avatar
Where are you located?
Old Apr 5, 2008 | 12:01 AM
Beeotch's Avatar
Annandale VA
Old Apr 7, 2008 | 01:34 PM
Beeotch's Avatar
Price Reduced $600 Shipped!
Old Apr 7, 2008 | 01:46 PM
alnielsen's Avatar
There are several different types of coilovers listed on the Megan Racing website.
Theres the Street LP, Euro & Track Series. Could you tell us what series these are? How about a part number?
Old Apr 7, 2008 | 01:51 PM
Beeotch's Avatar
Street Series
http://www.meganracing.com/products/...d=470&catid=93
part # MR-CDK-MRX8
"Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in **** at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Features:
- Spring Rates: 12kg Front and 10kg Rear
- 32 Levels of Adjustable Damper
- Pillow Ball Upper Mounts.
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coilover damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included"
Old Apr 7, 2008 | 04:25 PM
elysium19's Avatar
I never really thought about getting coilovers, but reading that sexy product description makes me think about it lol.... good luck selling those, they sound really sweet.
Old Apr 8, 2008 | 07:27 AM
Beeotch's Avatar
B
Bu
Bum
Bump
Bum
Bu
B
Old Apr 10, 2008 | 01:37 AM
kounterfeit402's Avatar
Still for sale?
Old Apr 10, 2008 | 01:48 AM
spivo-50's Avatar
still available
Old Apr 10, 2008 | 05:30 AM
Markx8's Avatar
How much delivered to Finland?
Old Apr 10, 2008 | 06:09 AM
Beeotch's Avatar
SOLD yesterday!
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
RX8mzda
Oct 1, 2015 10:17 PM
RAVSPEC
Vendor Classifieds
Oct 1, 2015 01:59 PM
