Failed PA Emissions Today
Old Apr 2, 2008 | 04:14 PM
MadRonin's Avatar
So I took the 8 in for inspection today and it passed everything but emissions. I replaced the battery last night 'cause it was dead (as in parrot) and my mechanic thinks that it failed because the computer hasn't had a chance to "catch up". He suggested I drive it for a couple of days and bring it back to see if everything had sync'd.
Does that sound right?
Old Apr 2, 2008 | 04:20 PM
alnielsen's Avatar
Yes, once the PCM has been reset it needs to be run for a while just to make sure all is well. This is to prevent people resetting the computer just to pass the emissions tests. If all was well before, it will be again.
Are you sure that the battery wasn't pining for the fjords.
Old Apr 2, 2008 | 04:35 PM
MadRonin's Avatar
Good to know. Thanks!
Mate, this bird wouldn't "voom" if you put four million volts through it! 'E's bleedin' demised!
Old Apr 2, 2008 | 06:24 PM
yeah, drive it around for several days and the PCM will check off all the internal system self tests
otherwise it looks like you cleared out your PCM CEL codes to pass the emissions test
Old Apr 3, 2008 | 12:34 PM
MadRonin's Avatar
Thanks guys! Now all I have to do is avoid THE MAN for a couple of days. Did I mention my inspection expired in February....?
Old Apr 3, 2008 | 01:59 PM
Nubo's Avatar
Lubricious
How badly did it fail?
Maybe your battery was simply tired and shagged out following a prolonged squawk.
Man, PA must really be sticklers. I'm in CA and even here we don't have to do emissions test for a few years on late-model cars.
gwailo
May 14, 2024 06:57 AM
gwilliams6
General Automotive
60
Nov 3, 2015 02:50 PM
Racingjunkie
Sep 29, 2015 05:05 PM
tommy26Germany
Sep 29, 2015 10:33 AM
