jack up car with body kit
Old Mar 31, 2008 | 07:23 PM
shodan's Avatar
Question jack up car with body kit
How do you guys do it?
I'm thinking about getting kit, but do i have to take it off every time i want to change tire or life the car up?
Old Mar 31, 2008 | 07:29 PM
llzjayarzll's Avatar
meow
you can take it off like an idiot or:
- buy a low profile jack (best route to go)
- drrive on wood planks and use regular jack
- buy a ramp that clears the front bumper and use regular jack.
pretty much common sense really. =p
Old Mar 31, 2008 | 07:31 PM
snipaz2420's Avatar
the bukkake master!
nope you shouldnt have a problem. i can get the oem jack under the side without a problem to change wheels. for the front i use 2 scissor jacks on the sides and lift the car up(with help from another person) until i can get the hydraulic under the front to jack it up
Old Mar 31, 2008 | 07:50 PM
shodan's Avatar
When i'm at home I can play with ramps and stuff.
I was worried about getting stuck in the middle of nowhere with oem jack only
If it can fit thats good. But i guess i won't be able to use stands in those spots where i use oem jack.
Little offtopic. I just got cai and going to install in on sun. Do i have to take whole bumper every time i want to clean it?
Old Mar 31, 2008 | 07:57 PM
imput1234's Avatar
I ♥ Drifting!!!
my car is lowerd, normally I just drive on a sheet of wood. Or use the factory jack to the jack the car a little bit, then use my low profile jack.
Old Mar 31, 2008 | 07:58 PM
chrism's Avatar
Misfit Moderator TnC
yes you gotta take the bumper off.....and with a body kit you just use the oem jack to start the car off and then use a hydraulic
Old Mar 31, 2008 | 08:38 PM
shodan's Avatar
thanks for info guys
Old Mar 31, 2008 | 10:29 PM
c0ldf1ame's Avatar
or u can get a low profile jack and some wood
Old Mar 31, 2009 | 06:07 AM
CTrx8's Avatar
space for rent
i actually just got a new hydraulic jack and was wondering the same thing so i'm glad someone asked the question.
Old Mar 31, 2009 | 09:25 AM
Sheehan's Avatar
Zoom Zoom
I have a low profile racing jack at my uncles garage I use.
Even this is too high.
After cracking a side-skirt setting the car back down,
I have learned to drive my car up on 2x4's on both the front and back tires.
I just keep two 2x4's in the garage and it makes things pretty easy.
Old Mar 31, 2009 | 02:29 PM
HockeyRX-8's Avatar
TNC
Search!!
Old Mar 31, 2009 | 02:51 PM
pdxhak's Avatar
Official Post Whore
lowered with kit = low profile jack + 2x4s.
Old Mar 31, 2009 | 05:14 PM
rx8mod83's Avatar
Lifting Rx8 Society
It took me two home made ramp designs before i got my setup right, depending on the design.. my Accolade kit was only a few inches off the ground so you have to be careful, as you can see in this pic there is not much clearing on kits..
Old Mar 31, 2009 | 05:17 PM
you have a free lo-pro jack in your trunk
That's the easiest way; just use it as a starter, then finish it it up with a 1/2 ton
Old Mar 31, 2009 | 05:19 PM
dozer's Avatar
on his 3rd rx8
^+1
Old Mar 31, 2009 | 05:20 PM
pdxhak's Avatar
Official Post Whore
I'd rather drive up on 2x6s then pull out the little jack.
Old Apr 1, 2009 | 09:38 AM
reaper1's Avatar
You know I've never given this a thought . Ill be stoping by my Home Depot this weekend for some 2 X 4 . Its better to be prepare .
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
9krpmrx8
Nov 5, 2015 11:45 PM
Mr.Durden
Aug 12, 2015 02:21 PM
digitalmonkey79
Jul 29, 2015 12:09 AM
AussieGray
Jul 16, 2015 03:58 AM
