Just installed my AP Pulley and WeaponR Catch Can...few questions...
Old Mar 27, 2008 | 11:43 AM
0_o Flash's Avatar
Smile Just installed my AP Pulley and WeaponR Catch Can...few questions...
I did a quick search and I got frustrated digging through post so don't tell me to search...ty
Ok so I have a Greddy SP2 exhaust, K&N Typhoon v2 on my car and it sounds great.
I just finished installing the AP Pulley, the Greddy Water Pump Pulley, and the Weapon-R Oil Catch can.
Now whenever I go above 7Krpm it sounds like my engine has sand in a blender lol Any ideas where this might be coming from? I double checked the tightness of the bolts on the pullies and the belts, so that is not it.
Any info someone may have I would greatly appreciate...
Old Mar 27, 2008 | 12:11 PM
HiTMaNN's Avatar
RX-8s Official Cool Guy
Search for marbles in a blender or sand in a blender you will have your answer.
Old Mar 27, 2008 | 03:11 PM
nuke0907's Avatar
Never Blend In
got any pics?
0_o Flash's Avatar
ok I just tried searching under the pulley and oil catch can not actual " sand in a blender " b/c I thought that would definitely not show up, so thanks a lot
Yes I do have pictures. I will be posting them up under the multimedia shortly. I have to take it to have it washed today
Old Mar 27, 2008 | 03:21 PM
nuke0907's Avatar
Never Blend In
cool. i'll be watching for those pics.
Old Mar 27, 2008 | 03:55 PM
Jon316G's Avatar
Grasshopper
Have someone in the car revving it to 7K RPM while you observe under the hood. Probably be the easiest way to narrow it down.
This will also tell us if this only occurs while driving or if this sound is noticeable while stationary.
Old Mar 28, 2008 | 10:11 AM
Salamanth's Avatar
I have the same issue and it appears to be coming from directly behind my passenger side firewall area. It's quite irritating but the stealership refuses to even investigate the cause of it.
Old Mar 28, 2008 | 01:00 PM
kersh4w's Avatar
Hit & Run Magnet
if you have MIAC (marbles in a can) long enough, you will lose your engine.
go to a dealership that will look into it.
Old Mar 28, 2008 | 01:18 PM
Silver_Surfer's Avatar
I4NI
Hard to belive its "MIAC" if the noises just started right after installing your AP pulley.
Did the plate behind the pulley fall off or did you take it off while changing the pulley?
Well that being said, what type of fuel you using? Octane rating?
Old Mar 28, 2008 | 05:42 PM
Jon316G's Avatar
Grasshopper
That plate is the eccentric shaft position plate and if it fell off, he would have a lot more issues (not to mention a CEL)
Old Mar 28, 2008 | 07:00 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
^+1..........you got that right!
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
yurcivicsux
192
Sep 12, 2017 10:54 PM
RXFEVER
Sep 11, 2016 02:51 PM
