help on buying a RX8
Old Mar 26, 2008 | 05:39 PM
Oxford auto sound's Avatar
Smile help on buying a RX8
I want to buy a RX8 but i need help on when i need to look for as in problems or things to look for in a good rx8. I dont know much about them so i want a little insite on what i should look out for when buying on here in canada. Anyone who is haveing problems or a normal problem i should look for would be helpful. thank for the help in advance.
I took a buddys car out for a drive a while back and loved it. For a rx8 that **** moves.
Old Mar 26, 2008 | 05:41 PM
CyberPitz's Avatar
Huge hole is huge
The RX8 isn't much different than any other car in checking for problems. I'd, personally, get a compression check to make sure, make sure the interior is in good standing, and there aren't any large stains everywhere.
Get a Carfax to make sure the car hasn't been through an accident, and if it was, find out what was done to it in order of repairs.
Old Mar 26, 2008 | 05:47 PM
is there not like normal problems with them that i should look for. IE if your buying a civic or integra you always look at the wheel wells for rust starting and how much oil is in the motor cuz we all know they burn oil. so are there any normal things to look for.
Old Mar 27, 2008 | 02:46 PM
thanks alot
Old Mar 27, 2008 | 03:17 PM
xsnipersgox's Avatar
One Shot One Kill
civics and integra burn oil?... tats news to me
Old Mar 27, 2008 | 04:32 PM
your joking right ???
Old Mar 27, 2008 | 05:30 PM
CyberPitz's Avatar
Huge hole is huge
I've not seen any sort of problems that are on RX-8's mostly...
*Like for the RX-7, the Idiot Light cluster would have fits, as would the wiper/headlight switch relays due to the bad cold soldering, or the horn as well...*
Just check the compression and make sure they do routine oil changes and don't let the engine run out.
Old Mar 27, 2008 | 05:40 PM
StealthTL's Avatar
Metatron
The ONLY serious longterm unsolved problem I know of is the poor connection to the steering motor, at the top of the radiator. Easily replaced under by the dealer if it happens, and easy to solder if out of warranty.
I've had many (many many) cars that used a LOT more oil than my '8.
S
Old Mar 27, 2008 | 08:24 PM
04RX8man's Avatar
Rotary Powered Countryboy
No PROBLEMS just be sure not to shut it down when it'snot warm, check oil, and a redline a day keeps the carbon away....(which is never a problem for me)
Old Mar 27, 2008 | 09:41 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Omg!
Old Mar 27, 2008 | 11:59 PM
grimnar13's Avatar
hmm, how to redline in mostly city traffic?
Old Mar 28, 2008 | 12:50 AM
superglue's Avatar
n00b post whore
Push the clutch in
05TR1CH
Apr 18, 2023 04:56 AM
Skyl3r
Dec 2, 2019 04:51 PM
mariohardleft
Sep 13, 2015 11:17 PM
Remixrussian
Aug 3, 2015 01:43 AM
robd1337
Jul 31, 2015 09:35 PM
