Int-X: no connection to ECU
Old Mar 16, 2008 | 12:30 PM
funklove's Avatar
Eunos Cosmo T61
Hi!
The mazsport's Int-X cannot connect to my laptop. The problem happened since I reinstall my windows and did not touch my car all winter . It was connected strong at autumn.
I have XP home edition and USB-com adapter cable. Zeitronix and haltech connects fine.
Any suggestions?
How can I test microtech DB9 adapter?
Thanks.
Old Mar 16, 2008 | 02:56 PM
ChattyRX8's Avatar
Now turbo!
Are you getting a message from the PC? If so, what exactly does it say? Is the Microtech software installed since you re-installed your operating system?
Old Mar 16, 2008 | 03:05 PM
Probably the Serial to USB adapter......check the Com port it is set to.....Microtech software used Com1 or 2 only
Using the dongle ??
Old Mar 16, 2008 | 03:14 PM
chickenwafer's Avatar
Nope
without the dongle it won't connect. Also make sure you have the right driver for the COM to USB adapter. If you PC has a COM port I would recommend just connecting it that way.
Old Mar 21, 2008 | 11:02 AM
funklove's Avatar
Eunos Cosmo T61
Thank you, guys!
I suppose the problem is in USB cable driver or XP version.
Yes, the "black box" was connected.
The last version of software downloaded (com port 1-4).
I'll test tomorrow.
Old Mar 22, 2008 | 08:39 AM
funklove's Avatar
Eunos Cosmo T61
The problem solved. I replaced USB driver.
Shankapotamus3
Mar 14, 2021 03:53 PM
Evan Gray
Nov 24, 2015 01:00 AM
archon
Oct 1, 2015 06:08 AM
RotaryMachineRx
Sep 29, 2015 10:26 PM
