What applications are good for "inverted" LED bulbs?
Rating: Thread Rating: 3 votes, 5.00 average.
Old Mar 14, 2008 | 01:48 PM
TheWulf's Avatar
My 8 looks like a Smurf
Ran across these and wondered if these would be a better choice than regular LEDs. It looks like they have a better, softer, more even light distribution. Thinking of getting these for all the 194 bulbs in my 8... thoughts?
Old Mar 14, 2008 | 01:54 PM
laythor's Avatar
I zoom therefore I am.
maybe license plate?
I just changed out my courtesy door lights to the 19smt blue's from v-leds. lots more light then what i had.
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
Old Mar 14, 2008 | 02:26 PM
TheWulf's Avatar
vleds's shipping prices are ripoffs for canada. I e-mailed them asking if they would give me something more reasonable, so we will see.
Also, I could get a dozen LEDs -- shipped to Canada -- 194s from ebay for the price of one of those sets you linked. As for price vs quality, I hear a lot of people saying their vleds burn out quickly, so I'd rather be out $20 than $100 if they burn out.
Old Mar 14, 2008 | 02:31 PM
Aipex8's Avatar
X e p i A
I bought a pair of inverted LEDs a long time ago to check them out and they aren't suitable for external applications. They only contain 1 LED and are very dim. You are much better off going with refractor type bulb that has many LEDs facing in different directions. I'm using the following for my parking lights for example:
Old Mar 14, 2008 | 02:42 PM
TheWulf's Avatar
As I said... vleds + shipping + canada = screwed.
My alternative is:
10 for $20 shipped! as opposed to $115 for VLEDS
Old Mar 14, 2008 | 02:47 PM
Aipex8's Avatar
X e p i A
I know you don't want to buy from V-LEDs, I was just showing you an example as other companies sell similar bulbs. The one you posted above will work. Also check out www.autolumination.com. See my response in your other thread about non-LEDs for my suggestion on buying or making "LED protectors" (1 Watt 100ohm for smaller clusters, 10 ohm for larger clusters) so your LEDs don't burn out. I've tried many different LEDs in my car (exterior and interior) let me know if you have any other questions.
Old Mar 14, 2008 | 04:12 PM
laythor's Avatar
actually it's autoilummination that most people have had issue with. I've yet to have a vled burn out on me.
Old Mar 14, 2008 | 05:15 PM
TheWulf's Avatar
Howlong have you had them? Are you using any resistors?
Old Mar 14, 2008 | 05:24 PM
Aipex8's Avatar
X e p i A
I've had both autoluminations and vleds burn out on me. I will agree that autolumination is the lower quality bulb mostly because their colors are not consistant. Burn out rate has been the same for me before using resistors.
Old Mar 14, 2008 | 05:30 PM
TheWulf's Avatar
Seems to be the consensus. I guess I'll wait for them to answer my messages... I shrug at the thought of paying nearly $200 for bulbs though... they better last!
Old Mar 14, 2008 | 06:03 PM
SayNoToPistons's Avatar
Wheels, not rims!!
My alternative is:
Where?
Old Mar 14, 2008 | 06:08 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Correct.............I wouldn't use autoilummination IMO.
I haven't had a VLED go out in over two years in some cases.
Think I'm using the 5led refractors in my map lights...............hell, I can't remember will have to go check my long annoying post.
Looks like I was only using the refractors in the map lights to fill out the lens more.
Well, I found it. Here's what I have at the moment. Hopefully the links work?
Parking lights.......white 6 LEDs http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
Clear Corners.......white 6 LEDs http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
Door Courtesy lights.........blue 6 LEDs http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
Map Lights..........blue 5 refractor LEDs.......Don't think they sell these anymore???? This is what they looked like, but not in purple/UV/black light.
Rear Dome..........blue festoon/LED http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
Glove..............blue 6 LEDs http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
Footwells, have two blue LED circuit boards each side(driver and passenger), these are a little more subtle that what you've probably seen.
Under the front seats(near the rear), I have RR's blue circuit boards tied into the Courtesy and Footwells above.
https://www.rx8club.com/group-buy-center-85/custom-led-footwell-lights-118507/
Turn signals.........Stealth bulbs for now. http://www.stealthauto.com/Departmen...lth-Bulbs.aspx
Inside Trunk.....blue 6 LEDs http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
License plate......white 6 LEDs http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481 or http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481 right now I have the 2nd one in there, the HID.
Brake lights........18 LED 7440/7443 red http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
Back up lights.........18 LED 7440/7443 white http://www.v-leds.com/Shop/Control/P...d/0/SFV/32481#
Fog lights...........Hoen H11's. This isn't where I bought them, but see............ http://www.hoen-usa.com/fog.htm
Puddle lights courtesy of Shazbot. https://www.rx8club.com/group-buy-center-85/custom-led-puddle-lights-118822/ BUT.....I did change out the LEDs to match those in the door courtesy light position.....see above.
RX8Strakes Stealth brake light, but I believe they stopped making them. http://www.rx8strakes.com/index.asp?...PROD&ProdID=31
Next up, I'm after all the dash and radio leds to blue, but that's gonna be a bitch! Unless I get Lurch to do it!
I think that's it unless I forgot something?
Yes, I am sick!
Old Mar 14, 2008 | 06:19 PM
laythor's Avatar
i'm not using any resistors cause i'm lazy like that.
Old Mar 14, 2008 | 06:22 PM
Easy_E1's Avatar
Mazurfer your links are not working.
Old Mar 14, 2008 | 06:40 PM
c0ldf1ame's Avatar
i went through so many bulbs on my front parking lights that i changed them back to regular bulbs,
Old Mar 14, 2008 | 06:41 PM
Mazurfer's Avatar
Fixed.......they changed the site!
Old Mar 14, 2008 | 06:42 PM
Mazurfer's Avatar
And the make was??????????????????????????
Old Mar 14, 2008 | 07:08 PM
Mazurfer's Avatar
Don't overlook your plate light. Funny, but it actually makes a big difference(at least to me).
Whatever you use for you clears and/or parking lights, I would use the same there.
You might be surprised!
Old Mar 14, 2008 | 07:10 PM
c0ldf1ame's Avatar
v-leds, not blaming the brand, cuz all the other LEDs i have are still good, just something wrong with the front parking lights
Old Mar 14, 2008 | 07:16 PM
Mazurfer's Avatar
Hmmmmmmmmm.........Swoope(I think) and I did both had a flasher in that passenger side parking light position one time.
Was that what you had or did they just burn out?.....and was it both sides or just one?
Inquiring minds want to know!
Old Mar 14, 2008 | 10:58 PM
TheWulf's Avatar
Originally Posted by SayNoToPistons
Where?
EBAY =)
https://www.rx8club.com/showthread.php?t=118507
Puddle lights courtesy of Shazbot. https://www.rx8club.com/showthread.php?t=118822 BUT.....I did change out the LEDs to match those in the door courtesy light position.....see above.
Yes, I am sick!
That's sweet... looking to do something similar. Are you using resistors on any of yours? And pics?
Old Mar 15, 2008 | 08:18 AM
Mazurfer's Avatar
Some of the VLED's come with resistors already there, but to answer your question................."No", I have not had to add any resistors on anything so far.
Remember this though................if you do the third brake light, the high center one, you will have issues with your ABS and maybe DCS/TCS. That circuit is really touchy and there is a fix somewhere on here about it, but I didn't really think it was worth it, so I left the bulb in that position.
Pics.............there are a few floating around on here. I'll see if I can find some, but I'm not much of a photographer. YOu could probably search my username and LED or something and come up with them.....I'll see if I can locate any. Here's a couple, but these weren't really showing the inside.
https://www.rx8club.com/showthread.p...06855#poststop
https://www.rx8club.com/showthread.p...14687#poststop
RX-Tuner
RX8Performance
196
Apr 16, 2023 02:19 AM
BigMikeATL
May 26, 2016 12:31 AM
CARBONRX-8
Aug 23, 2015 09:52 PM
Stubbs
Jul 28, 2015 09:23 PM
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
