Battery Drainage
Old Mar 14, 2008 | 03:34 AM
Psychofox's Avatar
我愛台妹,台妹愛我
Battery Drainage
Anyone know what's the normal battery drainage for our car when the car is off ?
Mine reads around 100 mA ...
I tried search but couldn't find any useful info. Thanks
Old Mar 14, 2008 | 06:53 AM
Speedsteve's Avatar
Speedsteve
battery
Hi there
100ma is a rather big dark current, (I think Mazda tells it should be 30ma by default). On my car I saw a 50-60ma dark current. I did have flat battery issues, but that was caused by the Interceptor EMS. I found the solution for that . If you have the Intereptor EMS, just do a search on my posts for the solution .
I you do not have he IntX then I would remove the room fuse and measure the current again. Maybe it is due to an extra device you have installed ?
Cheers
Steve
Old Mar 14, 2008 | 04:02 PM
Psychofox's Avatar
我愛台妹,台妹愛我
thank you speedsteve
I've send you an PM
Old Mar 14, 2008 | 06:03 PM
Nubo's Avatar
Lubricious
The original spec was no more than 30mA, later revised to 50mA.
Old Mar 14, 2008 | 06:05 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Yep, 50mA. or below.................Steve and I had an ongoing thread discussion on that one!
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Evan Gray
Sep 26, 2015 12:30 PM
