maxrx8
11-05-2003, 03:08 PM
Has any body tried these on their stock wheels?
I am looking at trying them. Mcgard said they should work with the specs I gave.
http://www.mcgard.com/automotive/details.asp?lock=TwoFullTops.jpg&key=LugTool.jpg
my10ae
11-05-2003, 03:26 PM
I have a set on my Miata and they look great...
maxrx8
11-05-2003, 04:30 PM
Are these stock or aftermarket wheels? The site says for aftermarket.
zoom zoom
Mitch
11-05-2003, 09:54 PM
Make sure that they are not tuner lugs.
carnut
11-07-2003, 10:42 PM
I don't know what tuner lugs are!
iamcanadian
11-08-2003, 12:08 AM
the lugs used on most aftermarket wheels are smaller than the stock wheels. check out this link for info: http://www.whalentire.com/tunerlugs.cfm
Brian Goodwin
11-08-2003, 12:44 AM
We use them on our track and street Miatas. More engagement with the stud surface as compared with the stock (miata) stud surface. They go on smoother because they have two pieces with a bearing in between the two parts so that the part that touches the wheel stops turning rather than grinding against the wheel surface...this makes them very easy to torque properly and they don't scratch the wheels.
Just flew back in from the SEMA show two hours ago and the hot deal in lugs this year were forged aluminum lugs....extremely light. Not sure how durable they will turn out to be but they sure feel great in your hands....will have to try some out.
Brian Goodwin
Good-Win Racing (http://www.good-win-racing.com)
carnut
11-08-2003, 02:38 PM
I always learn new things here. Thanks!
r0tor
11-10-2003, 06:56 PM
there anything wrong with the tuner lugs? ... my snow wheels have them :confused:
iamcanadian
11-10-2003, 10:26 PM
There is nothing "wrong" with them. They are meant to be used with aftermarket wheels that have smaller holes for the lugs than stock. I guess if the lug is seated properly against the rim it should not matter. Regardless, I would only use tuners on wheels that require them.
maxrx8
11-11-2003, 10:18 AM
McGard has them in tuner and cone seat. It says "aftermarket cone seat only" on the site.
After looking at the "tuner description" it doesn't say they can't be used for stock wheels. It seems as though they are made for aftermarket wheels that won't allow a normal socket to fit in custom wheel designs.
I just wanted to get a second opinion. You guys seem to know what's goin on in the world of the "8"
max
maxrx8
11-11-2003, 10:24 AM
I thought that I was seeing double.
Jhouse
11-12-2003, 05:44 PM
i use tuners in my 8 but i got tuner wheels 2
