FS: Mazsport Interceptor-X Wide Band Sensor Kit
SOLD
http://www.mazsport.net/store/index....ct_detail&p=30
- Allows the user to tune the engine to the target AFR by using the exact same data the Interceptor-X EMS is using to run the engine.
- Makes engine tuning a much simpler task because all of the required tuning data is on the same screen.
- Can be used for "Wide Open Throttle Runs" during dyno sessions or allows you to perform the majority of the tuning before the dyno session.
- Saves costly, hourly dyno rental time by allowing you to monitor and tune highway cruising AFRs in real time. Make and see the results of those changes instantly! This improved fuel economy will save you money at the pump.
- By using the Interceptor-X EMSs built-in ECU logger, track cars can record laps of data and download the info to the laptop to review later or fine tune your vehicle to a specific race track!
You weld the bung into your midpipe and screw in the wb02 sensor. Then you plug the 1/8" connector into the 1/8" jack that is labed wb02 on the front of you're interceptor-x.
Done.
(In the picture they are tucked under the black wrapped cable and tied up).
Those cables connect to the black box and the 1/8" cable coming out of the black box connects directly to the int-x front panel.
JimmyBlack
273
Feb 10, 2020 10:23 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
05rx8mazda
Nov 28, 2015 09:42 AM
yankeepicker
Sep 11, 2015 05:42 PM
