Recommended mods for beginners?
Old Mar 9, 2008 | 11:04 PM
texano03's Avatar
I'm new at this and I'm trying to get a good idea about what mods I should start off with. Everyone on this Web site far more knowledgeable than I about mods for the RX8. What are some good, easy bolt-on RX8 mods for beginners?
I have no one to teach me this stuff and I'm dying to learn! Please help!
Old Mar 9, 2008 | 11:11 PM
N rider89's Avatar
^NieL
clear corners are a simple mod that has a good diy guide on here. an intake isnt that difficult of a job and it makes you learn how to take off the front bumper.
Old Mar 10, 2008 | 01:03 AM
killer links here.
https://www.rx8club.com/rx-8-multimedia-photo-gallery-6/how-behave-forums-139802/
Old Mar 10, 2008 | 01:08 AM
imput1234's Avatar
I ♥ Drifting!!!
Go to a track day and learn what the RX8 can do.
Old Mar 10, 2008 | 01:18 AM
HiTMaNN's Avatar
RX-8s Official Cool Guy
Put some new Valve caps on the tires... that is super easy!
Old Mar 10, 2008 | 01:23 AM
LionZoo's Avatar
road warrior
First of all, what are you trying to accomplish? Second, how much money are you willing to spend?
Old Mar 10, 2008 | 02:29 AM
d j's Avatar
d j
hukbong himpapawid
+1
are you going for looks? performance?
welcome, btw! I'm guessing that you're stationed in Altus (unless your a dependent)
Old Mar 10, 2008 | 09:38 AM
texano03's Avatar
I'm looking for performance...looks isn't high on my list of priorities. You guessed right.
I know for a fact that I don't want to do forced induction, cuz it sounds way to complicated for my skill level (which is the lowest possible).
Here is my list: anything that isn't forced induction and that increases the torque/hp.
I know there are a lot of knock off parts and/or unreliable parts out there, I just wouldn't know them even if they hit me in the face.
I'd even be willing to volunteer to help someone just so I can get experience.
Old Mar 10, 2008 | 09:41 AM
texano03's Avatar
I'd love to do that, but I'm pretty far away from anything. Altus, Okla., is farm town USA.
Old Mar 10, 2008 | 09:49 AM
texano03's Avatar
I'm not looking to waste my money...but I'll keep that in mind.
Old Mar 10, 2008 | 09:54 AM
frollo's Avatar
you will find texan that the majority of the people here have found that bolt on's and anything other then fi will not give you a significant amount of hp/torque the best thing you can do is get a new tune (al la accessport) which will run you in the tune of 700+ and that nets about 15 hp or so. New exaust might get about 3, intake might improve the sound (and a hp or 2). Put in a mid pipe and remove cat and you might get some flames out the back... i'm sure you see the pattern, the car is fairly optimized from the factory. Again the biggest gains w/o fi is probably the map and if you look at the price per hp it is better then the other things you can do to your car.
Old Mar 10, 2008 | 12:40 PM
nelsonrx8's Avatar
exhaust,racepipe,flywheel,clutch,A/P,Nitrous
Old Mar 10, 2008 | 01:54 PM
texano03's Avatar
As of right now, the RX8 is my daily driver. I can't go crazy on it just yet. My #1 reason for wanting to keep it simple is that I want gain some experience while still keeping this as my daily driver.
If you take out the cat and add a mid pipe will the RX8 still meet emission standards?
So you're talking about putting in an ECU? What's the best one to get? Installation difficulties? Does an ECU automatically readjust every time you add a new mod?
Do you have a recommended list of mods/brands I should use?
Sorry about all of the questions...occupational hazard. I'm a journalist.
Old Mar 10, 2008 | 02:04 PM
bse50's Avatar
#50
If you want to achieve an increase in performance without going crazy i suggest that you buy a shorter final gear.
By far is the best mod i experienced on my ride
Old Mar 10, 2008 | 02:40 PM
kersh4w's Avatar
Hit & Run Magnet
lightweight rims
lightweight flywheel
some sort of ignition upgrade
cold air intake + revi ram air
a few track/autox events to help you realize the potential of the 8 is good too.
Old Mar 10, 2008 | 02:51 PM
staticlag's Avatar
The Professor
It's true, the 4.77 is one hell of a mod.
Old Mar 10, 2008 | 02:55 PM
kersh4w's Avatar
Hit & Run Magnet
and for those that do a lot of highway mileage, a real gas killer.
Old Mar 10, 2008 | 03:02 PM
Aero8's Avatar
Was this answered?
MT or AT?
If MT...
AFE Short Shifter - easy to install, fun to drive.
Old Mar 10, 2008 | 03:45 PM
tdiddy's Avatar
Finally Boosted!!!!!!!
Get the AccessPort and a Midpipe. Less than $1000 and you will feel the difference.
Old Mar 10, 2008 | 10:45 PM
sosonic's Avatar
1. Mazmart water pump
2. Mazsport ignition solution or upcoming alternate ignition solution.
3. Flywheel, if manual
4. Short shifter, if manual
5. Automatic Transmission Cooler and Redline High Temp AT fluid, if auto
6. Cold Air Intake duct. Racing Beat or Odula.
7. High flow air filter
8. Synthetic oil, 0W30
9. Amsoil long life oil filter
10. Oil catch can and breather mod, DIY section
11. Throttle Body bypass mod, DIY section
12. Exhaust, Greddy is good. Preferably weighs less, pipes are larger, and sound DB level near stock.
13. Larger oil cooler or 2nd oil cooler (if older 4AT).
14. Greddy oil pan, adds extra oil capacity
15. Redline Water Wetter for radiator
16. Redline gas additive, Redline 2 cycle oil as premix, or other premix.
15. Scangauge 2
17. Escort GT2 G-Timer or G-Tech Pro
18. Mazsport fan mod or other type fan mod (maybe unnecessary if have ECU reflasher and map editing software)
19. Electrical Grounding kit
20. Rear strut and member brace set.
21. ECU reflasher. Cobb AP, EFIdude, or Hymee
Old Mar 10, 2008 | 11:25 PM
Nemesis8's Avatar
Bigus Rotus
smoke it - slam it - bump it
Old Mar 10, 2008 | 11:51 PM
d j's Avatar
d j
hukbong himpapawid
short shifter
springs + adjustable shocks/coilovers
sway bars
you can install all those in the hobby shop.
Old Mar 11, 2008 | 09:27 AM
Socket7's Avatar
ಠ_ಠ
Performance mods for a beginner?
A good set of tires (the best car in the world is useless with crap tires) and the short shift mod.
Old Mar 11, 2008 | 11:56 AM
texano03's Avatar
Originally Posted by d j
short shifter
sway bars
Do all aftermarket mods come with DIY instructions, and do the auto hobby shop offer some kind of guidance or do I have to figure it out on my own (just wondering)?
what does the sway bar do for the car?
Old Mar 11, 2008 | 12:05 PM
staticlag's Avatar
The Professor
Most stuff you have to figure out on your own.
Some of the better companies provide instructions with pictures.
