RX-8 Engine Problems
Old Mar 5, 2008 | 06:44 AM
Talloes's Avatar
Hi, About 5 Months ago I purchased my 3rd car in my whole life and since Im paying for it I wanted it to be something I actually wanted. I bought it with 50,000 Miles on the car. I haven't had a problem yet till about a week ago when basically anytime I get close to around 6k RPM's the gas will cut in and out like im laying on and off of it. In 6th gear it wont go above around 4k RPM's and regular driving randomly it will feel as if im putting the gas on and off when im not. Im freaking out and I dont really have the money to pay the Mazda people to look at my car let along tell me how much money Im going to have to pay them to just ******* do 2 things to it. I live in the Tampa area and really need some help. If anyone has any clue or has run across this problem please help, I tried fuel Injector clearer but Im pretty sure it dident work but Ill give it a day or 2. Thanks
Old Mar 5, 2008 | 07:57 AM
Go48's Avatar
The car is probably still covered under the extended warranty that Mazda instituted a few years ago for these cars. As I recall it is 5 years or 60K miles. In any case, to verify, call the Mazda customer service 800 number in your owners manual or email them to find out. You will need to provide them with your VIN.
Then have a dealer check it out. Based on your description of the problem, it could be a failed coil(s), bad spark plug(s), clogged cat converter, or something else entirely.
Old Mar 5, 2008 | 12:33 PM
HiTMaNN's Avatar
RX-8s Official Cool Guy
Does a check engine light come on when your engine bogs? Have you ever changed your spark plugs, wires, and coils?
Old Mar 5, 2008 | 12:39 PM
mysql's Avatar
Doppelgänger
yep... they need to check your cat to see if it's failing, and then engine compression test to make sure the engine is OK.
both are still covered under warranty. So take it to a dealer.
If you're in Tampa, I highly recommend bringing it to Wesley Chapel Mazda (by 54 and i75)
Old Mar 5, 2008 | 12:50 PM
rotarygod's Avatar
Mazsport is in Tampa. Give Scott a call to see what he thinks.
Old Mar 5, 2008 | 12:53 PM
mysql's Avatar
Doppelgänger
I would recommend Mazsport too, but the issue described should be covered under warranty. No sense in paying out of pocket for it.
Old Mar 24, 2011 | 11:40 PM
balmaceda28's Avatar
hey im curious what ended up being the problem with your car??
vapor2
Nov 3, 2020 03:38 PM
Pelleilee
Sep 29, 2019 10:07 AM
Sifu
Aug 30, 2015 10:51 PM
MarkX
Jul 31, 2015 07:50 AM
Belalnabi
Jul 17, 2015 07:48 PM
