Driver's rear brake piston keeps turning...and turning....and turning....
Old Mar 1, 2008 | 07:35 PM
SouthFL's Avatar
.... and it barely makes any progress to seat flush again.
I've been turning this thing for about 5 minutes straight and it simply does not recede substantially. It maybe retracted a bit- enough to fit loosely over the old pads at 1/2 pad depth. Can't get the caliper to slide over the new pads. And yes, the slot in the piston is aligned with the pin in the pad backing plate.
Time for a caliper rebuild already? Car has only been driven 14 months. Perhaps tracking the car every 6 weeks has brought this on.
Old Mar 1, 2008 | 10:03 PM
costello's Avatar
You're using the tool right? I find it difficult to turn, but I think I'm turning and pushing at the same time. Not sure if that makes any difference. The rubber seal around mine is torn anyway.
Old Mar 1, 2008 | 11:17 PM
staticlag's Avatar
The Professor
I have to turn and push sometimes.
Old Mar 1, 2008 | 11:48 PM
SouthFL's Avatar
Using the correct tool no doubt about it. I did very little pushing however. Perhaps that was the issue.
I'll try again on Monday after tomorrow's track day. 1am isn't the time to start experimenting and I still have about 1/2 to 5/8th pad thickness on the old HP Plus pads, so I should be fine with the old pads. Guess I'll have to wait until next track day to test the Porterfield R4S.
Old Mar 1, 2008 | 11:56 PM
yep,
turn and push hard.
Old Mar 2, 2008 | 12:07 AM
SouthFL's Avatar
OK. Lol.
I've done pad swaps on this car a handful of times over the past year and I don't remember it being so difficult.
Old Mar 2, 2008 | 12:36 AM
Originally Posted by SouthFL
OK. Lol.
i am sure you have done many more than i. but i had that issue the second time i did a swap..
if you need a new caliper send me a pm..
Old Mar 2, 2008 | 12:39 AM
Easy_E1's Avatar
Push like your giving birth.
Old Mar 2, 2008 | 02:04 AM
ZoomZoomH's Avatar
Mulligan User
you answered your own question
sounds like a caliper that's starting to seize up.
Old Mar 2, 2008 | 02:50 AM
shaunv74's Avatar
Power!!
You definitely have to push in hard. Otherwise it will just turn and not retract. Keep pushing!
Old Mar 2, 2008 | 03:29 AM
987HYS's Avatar
Dragon Certified
just make sure you apply pressure when you turn it, and it should retract into the caliper
Old Mar 3, 2008 | 12:17 AM
RX-LS's Avatar
i have had the same problem on customers cars, sometimes what i do is use the tool and a c-clamp at the same time it pushs hard and turns and usually works
Old Mar 3, 2008 | 12:53 AM
SouthFL's Avatar
Thanks all!
Old Mar 3, 2008 | 02:45 AM
Brettus's Avatar
Boosted Kiwi
this thread sounds like an ante natal class ....
Old Mar 21, 2008 | 03:41 PM
SouthFL's Avatar
Finally took another shot at the pad swap today. The rear piston finally went in. Had to push very hard with every turn. Both driver and passenger side were a b*tch, but they went in.
Thanks all.
Old Mar 21, 2008 | 03:53 PM
Easy_E1's Avatar
Glad you got it in. Sometimes you meet with resistance when your trying to get it in. Just push real hard and it will go in.
Old Mar 21, 2008 | 03:54 PM
Derex'8's Avatar
ReDuX
I had this exact same problem but with the passenger rear piston. The Rear drivers side went in with just turning, while the passengers just kept turining, will give it a try again and apply pressure to the piston this time around.
Old Mar 21, 2008 | 03:56 PM
SouthFL's Avatar
Push like mad. Grunt, grit your teeth, feel your neck veins popping- and look up to see your neighbor staring at you like you're a mad man. It shall go in.
Old Mar 21, 2008 | 05:02 PM
shaunv74's Avatar
Power!!
Then he says: "What the hell are you doing to my wife!"
Old Mar 21, 2008 | 05:10 PM
SouthFL's Avatar
Lol.
Old Mar 21, 2008 | 08:04 PM
glad you got it!!
Old Mar 21, 2008 | 11:25 PM
It's easier when you remove the MC cap. then take out the extra fluid or put a rag there in case it spills.
Old Mar 22, 2008 | 08:54 AM
SouthFL's Avatar
Did all that.
Actually, I've been swapping pads many times over the past few years. The rears have been simply more of a pain in the *** now than before. Makes the concept of swapping pads at the track almost impossible. The Porterfield R4S pad set should be the perfect solution for this. If I get any fade, I can swap in an R4 set up front at the track and leave the R4S in back.
Old Mar 22, 2008 | 10:11 PM
Did all that.
i hear they are very good. i expect a review. when do you test them??
Old Mar 23, 2008 | 08:06 AM
SouthFL's Avatar
Haven't driven much yet with them on- just bed them in the other day.
April 20th, Homestead will be my next track venue. A full comparo vs. HP Plus will be had then.
Actually, Razz1 has had experience with them from what I've read.
