Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
Water in oil?
Old Feb 27, 2008 | 12:29 PM
reb0rn's Avatar
Water in oil?
I just returned from getting my oil changed and the tech told me that my oil was white and milky. he said it was from moisture inside the engine. The only thing I can think of getting water in the oil would be when I changed the spark plugs. The car flooded on me and the dealership told me to remove the plugs and let the fuel evaporate over time. Is there something that I can do aside from taking it to the dealership? I'm sure they'll charge an arm and a leg. I love this car but it seems to be quite the pissy little thing. The engine light is showing after the oil replacement.
04'
45k miles.
nothing maint wise, aside from normal maintenance.
I drive it pretty hard since the tech at the mazda shop said i should rag it pretty heavy from time to time.
Old Feb 27, 2008 | 12:30 PM
re-rx7's Avatar
EEwww Fresh!
Could be a coolant seal dying. Ever overheated??? Does it overheat now?
Old Feb 27, 2008 | 12:34 PM
expo1's Avatar
He's as bad as Can
Ask the tech where he saw the milky stuff. If it was on the dipstick its normal, don't worry. If he saw it in the pan he dumped the used oil in then there is an issue.
Old Feb 27, 2008 | 12:39 PM
VolcomStoneX's Avatar
Hi, Let's Make Out
your still under warranty take it in
Old Feb 27, 2008 | 05:27 PM
deadphoenix52's Avatar
meh.
its perfectly normal. your under warranty you can take it in. but it isnt anything detrimental.
Old Feb 27, 2008 | 05:41 PM
re-rx7's Avatar
EEwww Fresh!
I can understand a lil but sumthing that you will notice should not be considered normal! Indication of this usually tend to gravitate toward a coolant seal.
Just because it is not overheating does not mean it is not one. I hope it isn't but, do a coolant system pressure check top be sure!
Mazurfer's Avatar
Surf Hard, Drive Hard
.................10.......................
Before you ask............that's the count of milky oil threads since Winter began.
Happens every year.
I just decided to be an @ss and try to keep track this year.
Old Feb 27, 2008 | 05:42 PM
re-rx7's Avatar
EEwww Fresh!
Old Feb 28, 2008 | 08:00 AM
reb0rn's Avatar
ya it's only on the dipstick, how is that normal? i'm just begining to learn about this car i decided to purchase. and no it hasn't overheated
Old Feb 28, 2008 | 08:14 AM
Creto's Avatar
It's good to be the king.
Read here
No cause for panic.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
Sakebomb Garage
Sakebomb Garage
Sep 6, 2015 03:29 PM
