Someone please help me figure out how to connect to my INTx with a post 1980 laptop
Old Feb 24, 2008 | 10:40 PM
slavearm's Avatar
Boost Junkie
I have a laptop with no built in serial port. I am running WXP SP2 and have used 2 USB to serial adapters.
1 by my laptop manufacturer (IBM/Lenovo) that works with EVERY OTHER GD DEVICE IN THE WHOLE FLIPPING WORLD, but not my intx. (even when I changed the damn port to com1)
Another by some chinese el cheapo manu. (this one works with everything else also)
I have even tried letting the USB adapter sit on com7 and then used a virtual serial adapter on com1 that forwarded everything to com7. (yep I was gettin' desparate)
What do you guys use to connect. I got rid of my laptop with a built in serial last week. I need to find a solution pronto.
Thanks,
Slavearm
PS- I know my cable is good, because it works to my DASH.
Old Feb 24, 2008 | 10:47 PM
mysql's Avatar
Doppelgänger
i went to radio shack, bought the cheapest usb to serial connector they had. Installed the drivers, then hooked up the serial to usb dongle, then plugged into laptop. WinXP installed the device and then I went to system settings->hardware and changed it from whatever com port it defaulted to, to com1.
Then it worked. If I plug the dongle into a different usb port, the system starts fresh and I have to repeat the above process.
Old Feb 24, 2008 | 11:20 PM
ding, ding..
keep the old laptops alive..
Old Feb 25, 2008 | 11:24 PM
slavearm's Avatar
Boost Junkie
So... um.. Radio Shack doesn't keep them in store anymore, and I have bought 3 today and every single one of them used the same exact "Prolific" Serial to USB chipset, and not one of them has worked for me.
Old Feb 25, 2008 | 11:37 PM
laythor's Avatar
I zoom therefore I am.
start>control panel>system>hardware tab>device manager>com ports>find the com port for your serial connector and install driver.
Old Feb 26, 2008 | 07:27 AM
slavearm's Avatar
Boost Junkie
Grrrr.... you know what it is... the first two I bought are no bueno. The last two are fine, but it sure helps to plug in the POS ****DONGLE****
Why does Microtech do that crap when every other ECU doesn't?
TheWhiteAce
Aug 16, 2015 10:56 PM
Fister_Roboto
Aug 4, 2015 03:42 PM
