Canada available pre-mix
Old Feb 24, 2008 | 01:19 PM
SpIcEz's Avatar
What oil do you use for pre-mixing in canada, thats easily available ?
I honnestly dont feel like ordering stuff on the internet all the time.
Any good oil us canadians are using thats easily available ?
like at Canadian Tire or Napa/UAP, etc... ?
Thanks.
Old Feb 24, 2008 | 01:25 PM
StealthTL's Avatar
Metatron
CanTire, Shell Advance Full Synthetic, ISO-EGD rated.
http://www.pmaviation.co.uk/catalog/...tle-p-334.html
For snowmobiles and Rotax engines, so great for our motor, just avoid boat oil.
S
Old Feb 24, 2008 | 03:14 PM
philsbluerx8's Avatar
i just ordered 12 qt idfdafa(dont remember spelling) rotary pre-mix from mazdatrix. i am sure you can get some pennzoil oil from partsource or autovalue.
Old Feb 25, 2008 | 04:44 PM
wcs's Avatar
wcs
no agenda
Great question SpicEz.
I've been wondering this too.
Tnx StealthTL
Old Feb 25, 2008 | 04:47 PM
wcs's Avatar
wcs
no agenda
LOL StealthTL I just noticed you sig... and you responded to a PreMix thread.
Have you changed your mind on PreMix Stealth??????????
or are you makinge fun of the person that said that?
Old Feb 25, 2008 | 05:50 PM
delhi's Avatar
Grand Chancellor
The Pre-mix thread are in gallons and oz. What would be the measurement in metrics?
Using the 400:1 ratio: Say 60L (full tank) how many L or ml of premix..... 150ml?
Old Feb 25, 2008 | 11:28 PM
R.P.M.'s Avatar
Rebuilds anyone?
100:1 is what I always pre-mix to.
60L tank gets 600mL of oil.
Make sure the oil is rated TCW-3 or it will settle to the bottem of the tank. TCW-3 oils are designed to actually mix with the fuel.
Old Feb 25, 2008 | 11:38 PM
SpIcEz's Avatar
Wow, thats allot.
Im still trying to learn, so I really dont know what Im talking about, but thats 20 ounzes, seems like ALLOT for 1 tank of gas.
Old Feb 26, 2008 | 12:15 AM
R.P.M.'s Avatar
Rebuilds anyone?
60L is alot of fluid also
I premixed a daily driven RX-7 for 3 months using 100:1 ratio and it didnt seem to smoke abnormally once warmed up. I also didnt have an OMP hooked up.
BTW premixing everyday at the pumps for 3 months really sucks
Old Feb 26, 2008 | 12:22 AM
SpIcEz's Avatar
600ml of what did you put ?
The cost of a 600ml pre-mix every tank will really increase your cost per tank unless its really cheap, no ?
Old Feb 26, 2008 | 12:23 AM
TurboEight's Avatar
Booost.
Any problems with a clogging fuel filter Joe?
why not get the OMP adapter?
Old Feb 26, 2008 | 12:28 AM
StealthTL's Avatar
Metatron
150:1 is lots because the original OMP is still functioning.
If you fill at the warning light, the tank will take 50 litres, so 150:1 would be about 333 mls, or ten ounces.
I would avoid TCW-3 oil unless it is also rated ISO-EGD or JASO-FC or better. Boat oil that meets either of these standards is OK.
S
My sig is just a quote from some random critic of the whole idea of pre-mix.....
Old Feb 26, 2008 | 12:29 AM
R.P.M.'s Avatar
Rebuilds anyone?
I used cheap 2 stroke premix oil. Something like $3-5 a litre. So putting in half a litre per tank doesnt cost that much.
Never had any problems with fuel filters ever.
At the time, I dont think there was such a product.....Im talking years ago when I was just a young buck
Old Feb 26, 2008 | 12:31 AM
R.P.M.'s Avatar
Rebuilds anyone?
BTW I was running 100:1 with NO oil metering pump attached to my engine at all
Old Feb 27, 2008 | 08:59 PM
Marcel's Avatar
Pre mix?
premixing is for Two stroke engines.
THESE ENGINES ARE NOT TWO STROKERS.
You will get carbon build up on your rotor tips and will scratch your chamber wall and loose compression. YOU WILL VOID YOUR WARRANTY.
Use only the 5W20 oil wich needs to burn of clean.
Cheers.
Old Feb 27, 2008 | 10:17 PM
Element's Avatar
Is this stuff okay?
According to Shell publication:
http://www.shell.com/static/ca-en/do...cants/1-14.pdf
Shell Advance Snow Ultra High Performance Synthetic Snowmobile Oil is specially formulated to pro vide superior engine
protection in all high performance snowmobile engines. This low ash, full synthetic formulation exceeds the highest requirements
in the industry categories recognized by snowmobile manufacturers including API TC, ISO-EGD and the JASO FC standard.
Old Feb 28, 2008 | 12:31 AM
SpIcEz's Avatar
Marcel I can see you are new here.
You should read up on the tech section threads about, oil, pre-mixing, etc...
All Rotary engines survive better with pre-mixing.
5W20 is debatable. Seems 5W30 is whats bests.
Pre-mixing is for engines that require lubrication for the seals. Rotary engines fit in that category.
The new Renesis engine has more lubrication, which would show that ours probably needs it as well.
Look up posts by RotaryGod, you'll see what I mean.
Old Feb 28, 2008 | 02:16 PM
Agent008's Avatar
Licenced to Race
I have been using 4oz/tank of Lucas Semi-Synthetic 2-Cycle:
http://www.lucasoil.com/products/dis...tid=3&loc=show
But I plan in switching to Amsoil Saber Professional:
http://www.amsoil.com/storefront/atp.aspx
Old Feb 29, 2008 | 05:56 PM
SpIcEz's Avatar
Thanks for the input.
I have found some Amsoil SABER Professional today, and will be trying it out. It was about 16$ with tax at a local Bike shop.
I think Bike shops are our best bet for finding this stuff.
BTW, found out a friend of mine used to have a ROTAX engine on his little paraplane or glider, whatever they are called. He no longer has it, but has a galon left of the premix he was using. He'll check out what it is and if its good, he'll give it to me. Hopefully its something I can use
Old Feb 29, 2008 | 11:00 PM
delhi's Avatar
Grand Chancellor
superstore carries Esso 2-stroke bike premix, iso-egd rated for $4.xx/l.It says pre-mix and low ash. OK to use?
Old Mar 1, 2008 | 01:02 PM
Marcel's Avatar
pre-mix
Guys, when I take my 2007 RX8 out for a good run on average I will have to add about a 250 ml to 500ml of oil to bring it back to where it should be on the dipstick.
If you make the calculations the metering pump injects morethan enough oil to lubricate the rotor tips. The main bearings are pressure lubricated by an oil pump
using motor oil. A two stroke engine depends on the pre-mix oil to lubricate the bearings and needle bearings on the connecting rods and wristpins.The rotary engine does not need pre-mix in the fuel. Also by premixing you may plug your catalatic converter due to carbon and ash build up if not driven hard at a regular basis to burn it of. Premixing should in my opinion be not neccesary unless in extreme hot temperatures and continuous operation in the upper part of your tach. The latter will result in a no driver license situation. Mazda's metering system
works verry well. (to offer a 100.000km warranty thisystem has been proven over and over). Any ways this is only my personal opinion on this matter.
Cheers,
Old Mar 1, 2008 | 04:39 PM
SpIcEz's Avatar
I think again you should read up on the posts here.
The amount of engine problems is one thing.
But also, the fact that the new renesis has more oil injectors.
If that doesnt prove that the engine needs more oil, Im not sure what will convince you.
Old Mar 3, 2008 | 09:40 PM
SE3P_DriftBoi's Avatar
Rotory Xtreme
sorry guys, I knw this might be a stupid question but I really wondered that do we add these premix oil to gas tank or engine oil tank? I really wanna make sure cuz I don't wanna screw up the engine....><
Old Mar 3, 2008 | 10:50 PM
SpIcEz's Avatar
If OMP is still working, add like 4oz to gas tank before a 50L fill up.
Old Mar 4, 2008 | 01:16 AM
Rotory Xtreme
what is OMP?? @_@
