brake piston (cylinder?) seal
Old Feb 17, 2008 | 02:25 PM
kersh4w's Avatar
Hit & Run Magnet
i think that image sums it up pretty succinctly. i teased the seal out after 5 minutes. but i'd like to know what i can do so i dont fear ripping it when im retracting the brake piston in the future.
Old Feb 17, 2008 | 02:29 PM
staticlag's Avatar
The Professor
grease it
Old Feb 17, 2008 | 08:45 PM
kersh4w's Avatar
Hit & Run Magnet
with what?
Old Feb 17, 2008 | 09:30 PM
Any thick greae will do. Wheel bearing grease.
don't use too much.
Old Feb 17, 2008 | 10:29 PM
invasion08's Avatar
Gloves? who wears gloves
Old Feb 18, 2008 | 12:51 AM
ken-x8's Avatar
Grease? Really? I've never heard of anyone greasing rubber parts on brakes. Generally, the only thing used to clean or lube that kind of thing is brake fluid. Seals get lubed with brake fluid. If a boot does not slip on dry, use a few drops of brake fluid.
Speaking of boots - that part is a dust boot, not a seal. If it tends to do that when retracting the piston, retract it slowly and guide the boot along the way.
Ken
Old Feb 18, 2008 | 02:36 AM
staticlag's Avatar
The Professor
Any grease works fine.
Old Feb 18, 2008 | 12:49 PM
kersh4w's Avatar
Hit & Run Magnet
pretty boys with dates on the weekends.
Old Feb 18, 2008 | 01:37 PM
Startl_Respons's Avatar
Yeah but we saw your pic that you tried to stick in the face of that girl in the other thread. People were like what the hell. Are you sure girls go for you?
Old Feb 18, 2008 | 06:31 PM
Go48's Avatar
DO NOT USE A PETROLEUM GREASE ON RUBBER! It wil swell the rubber and make it useless. Use a dielectric grease that is safe for rubber.
BTW, I think that is a dust shield and not a seal. If it was a seal, you would have brake fluid gushing out all over the place.
Old Feb 18, 2008 | 06:50 PM
invasion08's Avatar
Yes that is a dust shiled
Old Feb 21, 2008 | 04:26 AM
TrochoidMagic's Avatar
is adjusting valve lash
use silicone lubricant. it goes on lighter
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
vapor2
May 4, 2020 03:53 AM
Road Cone
Nov 6, 2015 01:52 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
