sirius oem sat antenna
Old Feb 17, 2008 | 08:49 AM
WRXtoRX8's Avatar
Winning is Everything
if you look at the shot of my car and look at the trunk I have the huge bump ant and want to get ride of it
http://barthmullinsracing.com/wp-con...07/11/fast.jpg
I want the small one that is pictured here
http://www.finishlineperformance.com...s/P/sirius.jpg
any one know if the small antenna is included in the Installation kit like what is listed here
http://www.buymazdaparts.com/parts.c...=RXS8&catid=12
Old Feb 17, 2008 | 07:02 PM
WRXtoRX8's Avatar
no one has any ideas?
Old Feb 17, 2008 | 07:09 PM
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
I was not aware that satellite radio required an outside antenna. The one that was in my truck (before it was stolen) had a small antenna that was laid out on the dash.
Old Feb 18, 2008 | 03:05 AM
WRXtoRX8's Avatar
yeah here is sirius install notes
http://www.sirius.com/servlet/Conten...=1173329546779
Old Feb 18, 2008 | 06:33 AM
Phil's 8's Avatar
Originally Posted by WRXtoRX8
Dam, I sure wanted satilite radio again but not enough for an ugly exterior bump.
Old Feb 18, 2008 | 06:37 AM
lurch519's Avatar
www.evoperform.com
you can always install the antenna underneath the cover on the rear deck
Old Feb 18, 2008 | 09:16 AM
WRXtoRX8's Avatar
lol yeah well that is part of the reason I want the smaller one as it is a lot less noticable compared to the huge bump I have now.
also on my soon to be wifes wrx I just mounted it with double sided tape on the cowl and ran the wire in the door area. you can't even see it unless you look for it.
Old Feb 18, 2008 | 11:34 AM
Phil's 8's Avatar
I assume that the cover of the rear deck would be the inside of the truck door?
Old Feb 18, 2008 | 03:15 PM
lurch519's Avatar
www.evoperform.com
i assume you mean the truNk?
no, it is not, it would be under the same covering as the rear speakers, on top of the deck but under the cover. works fine, thats where mine is and i relocated another members antenna to the same area with their factory sirius antenna
Old Feb 18, 2008 | 03:40 PM
Phil's 8's Avatar
Ya the trunk - I can't spell worth a s#@^ and have forgotten how to use the spell check
Old Feb 18, 2008 | 03:45 PM
WRXtoRX8's Avatar
alright well guess no one knows lol
there are some cuts in the antenna wire from the original install from original owner and would like to replace the antenna with the smaller one and mount inside possibly and/or on the trunk
Old Feb 18, 2008 | 03:50 PM
Phil's 8's Avatar
That would have to be an installer item as I would never attempt to run the wires there. Might be easy for you. I'll check with Best Buy installers.
Old Feb 18, 2008 | 05:21 PM
Marc_H's Avatar
I had my factory sirius antenna mounted on the rear deck right in the center between the speakers for the very reason you mention. I did not want an unsightly bump on the exterior of the car.
It works well and I've never had any problems with it.
I had it done at the dealership right after I bought the car in 2005.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Quiggs321
Sep 30, 2015 05:34 PM
FubarI33t
Sep 28, 2015 08:45 PM
ErwinN
Sep 23, 2015 09:29 PM
