thing attached to the oem air filter
Old Feb 15, 2008 | 08:11 PM
jay.sass's Avatar
i took my air box off. when i went to put it back on i pulled a small hose attachment off. the attachment was connected to a cylinder that attaches to the oem air box. i have no clue what it is. i started my car and there wasn't a check engine light, and it didn't run funny. any idea what it was that i broke off, and or any problems that it may cause if i don't fix it asap! thanks!
Old Feb 15, 2008 | 08:13 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Ummmmmmmmmmm.....catch can possibly?
Anybody?
This may be a new car for you, but did you buy it used?
That description kinda sucks......can you take a pic?
Old Feb 15, 2008 | 08:16 PM
Is it the VFAD solenoid?....It will have a wire plug connector..and a couple of small hoses...
Old Feb 15, 2008 | 08:20 PM
Mazurfer's Avatar
Thought about that, but it's been so long since mine is off I couldn't remember where the VFAD plugged in.
Old Feb 15, 2008 | 08:24 PM
I can't even remember what the stock intake looks like
G3tR3DDY2GR3DDY's Avatar
i believe hes talking about the VFAD solenoid... it kinda snaps into the rings and if you dont have it connected and its left open it can cause jumpy idling. If you leave it off be sure to cap off the hose.
Old Feb 15, 2008 | 08:31 PM
jay.sass's Avatar
thats it it sits in two rings.
Old Feb 15, 2008 | 08:36 PM
ya just make sure you cap off the open end of the hose if you take it out.
Old Feb 15, 2008 | 08:39 PM
jay.sass's Avatar
ignorance-cap it off. how? tape?
Old Feb 15, 2008 | 08:48 PM
Get a vac cap from an auto supply store...or use a short piece of hose and block it off with a bolt...or such
Old Feb 15, 2008 | 09:06 PM
DOMINION's Avatar
I don't buy Kool-Aid
Can you point it out in this pic?
https://www.rx8club.com/attachment.p...4&d=1146103133
Old Feb 16, 2008 | 03:48 PM
StealthTL's Avatar
Metatron
The "thing that fits in the clip" is a small vacuum accumulator that provides "suck" to the VFAD flap at low rpm.
The actual solenoid is under the filter box.
Cap off the vacuum nipple under the throttle body if you disconnect anything.
S
ironj221
36
Jan 20, 2026 08:28 PM
05TR1CH
Apr 18, 2023 04:56 AM
uZu
Dec 30, 2015 12:35 PM
GK1707
Dec 2, 2015 10:01 AM
MrORAN6E
Jul 24, 2015 09:32 AM
