New Owner... engine sqeeling?
Old Feb 14, 2008 | 08:02 AM
PBII's Avatar
Question New Owner... engine sqeeling?
I just got my dream 3 days ago, owned a few rx7's but none compare!!
There is a low squeel/beep coming from the engine bay, the service explanation was the air intake, but this is really high pitched and pronounced and I can only hear it when idleing (obviously). Am I just stupid or does everyone else hear this? REALLY appreciate any answers.... - living a rotary dream...
Old Feb 14, 2008 | 08:12 AM
mysql101's Avatar
there can be a high pitched sound from the engine as air passes some stuff.
see if it sounds like this:
http://video.google.com/videoplay?do...31036891&hl=en
if it does, then it's normal.
Old Feb 14, 2008 | 08:18 AM
alnielsen's Avatar
If it's not coming from the intake, I would check the belt tension or one of the accessories the belt drives. A loose or worn drive belt would squeal. Also, a bearing in the alternator going bad could make such a noise.
Old Feb 15, 2008 | 04:50 PM
Blackfd3's Avatar
+1 ^. Check these as alnielsen explained above.... Also you can remove the belt start the car and run it with out the belt. Only for a few seconds though. Did the noise go away? If so replace the belt and check all belt driven accessories, like idle pully, alt, etc etc.
Old Feb 15, 2008 | 05:08 PM
Detrich's Avatar
幹他媽!
more like a pig or like a rabbit?
Old Feb 15, 2008 | 06:59 PM
update? My first thought was the belt. Does it happen at all times?
The car does have a natural high pitched sound (as mysql pointed out) Probably won't be anything major.
BTW: CONGRATS on the car!!!
Old Feb 15, 2008 | 07:30 PM
chancejat's Avatar
Drive it like u stole it!
tighten your belts...
Old Feb 15, 2008 | 10:00 PM
DOMINION's Avatar
I don't buy Kool-Aid
Wink
Could it be the serpentine belt?
Old Feb 15, 2008 | 10:07 PM
chancejat's Avatar
good call....
Old Feb 16, 2008 | 03:51 AM
DOMINION's Avatar
Well its just that a lot of them have been doing this in the last month that I have been reading on this site
Old Feb 18, 2008 | 03:36 AM
PBII's Avatar
Thanks HEAPS everyone... looks like the squeel (not a pig!!) more like a ringing in your ears after a big night...- is normal. It starts off as a ringing then between 3 and 4krpm it gets louder like a whistle, then the engine noise drowns it out. Apreciate all your help, hope this answers some other new owners Q, their just so diff to the 7, but diff I like!!
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
badinfluence
Series II Aftermarket Performance Modifications
Aug 31, 2015 11:51 AM
Eirulisse
Aug 15, 2015 12:34 PM
MolecularConcept
Aug 9, 2015 04:46 AM
