Acceleration
Old Feb 13, 2008 | 12:40 PM
shinka2150's Avatar
Acceleration
So after doing search after search i have decided to start a thread hoping to get the answers i am looking for. I am looking for solid, proven ways to increase acceleration without going FI, too much to maintain, i already know about intake, exhaust and flywheel, but what else out there has been proven????
Old Feb 13, 2008 | 12:48 PM
nelsonrx8's Avatar
racebeat flash
Old Feb 13, 2008 | 12:53 PM
the_duke313's Avatar
4.77 gears r supposed to be real good, i want em' bad
Old Feb 13, 2008 | 12:59 PM
stuartm's Avatar
Your mods mean squit
Lightweight 17's, same effect as 4.77 diff + brake/cornering is improved
Oh & they're easier to fit
Old Feb 13, 2008 | 01:05 PM
nelsonrx8's Avatar
noway.......... really i hope not since i was looking into the 4.77 gears
Old Feb 13, 2008 | 01:18 PM
rotarygod's Avatar
Everything listed here is pretty much the limit in what will help you with acceleration off the line. The only other thing that hasn't been mentioned is weight reduction. Get rid of every excess pound you can.
Old Feb 13, 2008 | 01:54 PM
nelsonrx8's Avatar
damn time for a diet
Old Feb 13, 2008 | 02:08 PM
rotarygod's Avatar
That goes for the car too!
Old Feb 13, 2008 | 02:40 PM
Brettus's Avatar
Boosted Kiwi
masport coils are looking very promising
Old Feb 13, 2008 | 03:00 PM
stuartm's Avatar
^Yeap, My ps3 might have to go on fleabay to help the cause
Old Feb 13, 2008 | 03:46 PM
Revvittupp's Avatar
Noone said NOS...
Old Feb 13, 2008 | 04:44 PM
nelsonrx8's Avatar
^^^he said without FI^^^^
Old Feb 13, 2008 | 06:23 PM
Fanman's Avatar
Interceptor X will give good gains, but a bit pricey. You have a hi- flow cat that will give you some hp. Pullies will give you a few hp, but other than intake, pully, chip/ecu, hi flow cat., cat back exhaust, that is about all you can do to gain some NA hp gains.
Old Feb 13, 2008 | 06:33 PM
HiTMaNN's Avatar
RX-8s Official Cool Guy
Man up and FI, you gotta pay to play son
Old Feb 13, 2008 | 06:41 PM
staticlag's Avatar
The Professor
Yeah but....
4.77 gears give you the option of going to 19" wheels for the same as stock feel but better looks.
and the option to go to 17" wheels as well, and get 5.12 gear performance.
Old Feb 13, 2008 | 06:59 PM
Fanman's Avatar
Also, to the original poster I hope you realize the downsides of upgraded gears.
Old Feb 14, 2008 | 07:02 PM
ya but like hitmann said "you gotta pay to play son" haha
Old Feb 14, 2008 | 09:07 PM
CnnmnSchnpps's Avatar
No means yes
light
weight
fly
Old Feb 14, 2008 | 09:08 PM
staticlag's Avatar
The Professor
Originally Posted by CnnmnSchnpps
light
weight
fly
and clutch
Old Feb 14, 2008 | 09:31 PM
No means yes
actually the ACT clutch pressure place that I have is heavier than the stock clutch (per CRH). when the aluminium clutches by BHR hit the market, then yes, "and clutch "
Old Feb 14, 2008 | 10:24 PM
SolarYellow510's Avatar
235/40-17 tires are the equivalent of a 4.77 gear with 225/45-18 tires.
You can run them on lightweight and fairly inexpensive 17x8 wheels, which can save 7.5 lb each or so compared to the stock wheels.
Go with a light battery to take 12-15 lb. off the nose, and an "Isley" exhaust to take 22 lb. off the rear.
Should wake the car right up.
Old Feb 14, 2008 | 10:39 PM
Why is it sleeping?
Old Feb 14, 2008 | 10:48 PM
RedefineRX8's Avatar
Super-impreza!
it had a bad day at work.
I hope you mean 7.5 pounds each with tires, because the stock wheels aren't really that heavy. I weighed mine in at 21.5 lbs. I don't see you getting 14 pound 17 inch wheels inexpensively. Even if thats what you meant then, I think you are pushing it here.
Old Feb 14, 2008 | 11:00 PM
No means yes
^ The absolute weight savings may seem small, but this is unsprung weight, so it helps alot for handling..
Also, as far as acceleration goes, air and rubber is much lighter than metal, so getting the metal part of the wheel+tire combo to have a smaller diameter helps alot with rotational inertia. Kind of like the effect of a lightweight flywheel. Even though the weight difference may not be huge, the inertia is significantly smaller.
Old Feb 14, 2008 | 11:12 PM
Super-impreza!
um... i know that...
I'm saying how much weight per corner. 7.5 pounds per wheel is a riduclous weight savings and also nothing that will come inexpensively. You are looking at forged magnesium to attain weight loss like that from wheels alone.
