Grounding Wire Install
Old Feb 13, 2008 | 12:03 PM
ninjanick's Avatar
I followed the DIY section for installing your own "custom" made grounding wires and I'm wondering if there is a torque for the alternator tensioning bolt. Or is there a procedure for tightening this bolt back to factory spec?
Old Feb 13, 2008 | 02:22 PM
ninjanick's Avatar
NM ... found it. For anyone interested ...
Bracket Bolt ~20ft-lbs
Lower (14mm) ~35ft-lbs
Belt Tension 4.5mm - 5mm (don't have a tool so I made my best guess on applying 90N-m of force ... :/ )
LMURailsplitter02
Sep 6, 2015 10:56 PM
mattymack
Sep 6, 2015 10:33 PM
Rupanrx
Sep 4, 2015 06:44 AM
