Campacitor and a second amp install not going so good!
Old Feb 11, 2008 | 03:09 AM
DOMINION's Avatar
I don't buy Kool-Aid
Unhappy Campacitor and a second amp install not going so good!
OK so I got everything installed and hooked up that I was told I would need, in my pre-thread
What I'm trying to install; 4-3-2 channel kenwood amp on the left and a second (800w) amp on the right for my kenwood (4om) 12"
Pic one;
From battery; 4g ground from battery to engine strut bar, 4g 100w fuse to capacitor with charge card, 4g capacitor ground to trunk of car, 4g from capacitor to dis-block and to 4 channel amp, 12w or v blue wire also runs to second amp
12 w or v blue wire from first amp to second amp, 4g from dis-block, 4g ground to trunk of car, + red wire from sub to box mount now black wire to left side of amp and - white wire to right side of amp connection
In this pic the two amps are connected like this; line out from the amp on the left to line in to the amp on the right, black to with on top and gray to red on the bottom. Did I got that right?
So my prob is my capacitior will not charge and my second amp on the right will not turn on=no sup?
The instructions that came with my capacitor say; I need to connect the charge card to the capacitor or connect the blue wire to + and the yellow wire to -
Then connect the red wire to + and the black wire to - to a 12 volt DC power source. When the green led light goes out, the capacitor is charged.
I dont know what to do next?
Guys please let me know if everything is hooked up right
Thanks a million!
-Gil
Old Feb 11, 2008 | 03:30 AM
DOMINION's Avatar
Oh ****. Well this is why my capacitor is no t working lol
http://www.rockfordfosgate.com/scrip...%3Afaqs.faq_id
Hell I never used one before. I'm going to charge it right now to my battery and then hook it back up. BRB...
Old Feb 11, 2008 | 04:04 AM
WikkedOne's Avatar
Deals on wheels
The cap is charged by now.. I personally think the charge card isn't necessary anyways.. so just remove the card and let us know how it's goes
Old Feb 11, 2008 | 04:06 AM
WikkedOne's Avatar
Deals on wheels
oh yeah - switch the little switch on your amp from "stereo" to mono and make sure the sub is hooked to the left channel
Old Feb 11, 2008 | 04:26 AM
DOMINION's Avatar
I just tryed what the link I posted states you should do and still nothing
Man its cold out side.
The 12" is in the left channel. Its kinda hard to see in the pic. I just move the switch to mono.
Still no sound from the 12" and no lights are light on the second amp to the right
Old Feb 11, 2008 | 04:39 AM
DOMINION's Avatar
My Dis-Cap has one in from the cap and three out, Should I try to connect the second amp to the one in the middle? Right now its connected on the far right hole.
Old Feb 11, 2008 | 04:44 AM
WikkedOne's Avatar
Deals on wheels
have you completly removed the charge card? if you haven't thats your problem.. as for the dis cap - unless there is fuses inside there i cannot see it shouldn't be causing any problems..
Old Feb 11, 2008 | 04:45 AM
DOMINION's Avatar
I took off the charge card and there is no fuse inside the dis-cap, but still nothing
Old Feb 11, 2008 | 05:12 AM
WikkedOne's Avatar
Deals on wheels
Check your fuses and test your ground on your 800W amp and let us know the the results.
Old Feb 11, 2008 | 05:14 AM
DOMINION's Avatar
Cool
You where right, the ground for the amp on the right was for ****
So I did what you said. I ran a speaker wire from my cap to the ground on the second amp and bingo! we now have bass!
Thank you sir! you are the man!
Old Feb 11, 2008 | 05:18 AM
DOMINION's Avatar
Cool
I ran the 4g ground from the cap to the top of my trunk to a bolt. So I had just enough 4g ground wire to run the second amp to the same bolt.
Boom baboom baboom boom! lol I love it
Now I just need to have my box cut, bolt the amps down and mount the 12"
Old Feb 11, 2008 | 05:34 AM
WikkedOne's Avatar
Deals on wheels
saweet! Glad I could help man - just call again if you need some more help - oh yeah while your waiting for your box, find a way to hide all of your wires.
A good tip is to cut a piece of 1/2 inch plywood the exact size of your amp and put it under the amp under the carpet, then screw your amps down through the carpet into the wood - then cut little slits to run the wires into the carpet and next to the wood.. Its quick, easy, and clean. it also holds your amps in place! Happy bumps bro.
Old Feb 11, 2008 | 11:14 AM
He||hammer's Avatar
Destroyer of Dreams
You might have better luck hooking the cap up to th battery directly, it should only take 1-2 minutes to fully charge it, and where do you have the ground at ?
Old Feb 11, 2008 | 09:14 PM
DOMINION's Avatar
^Thanks but I'm now
I installed my second 12" and it sounds real sweeeet!
rotarywanker
Dec 8, 2022 05:56 PM
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
delicious_dallan
Jan 17, 2020 09:17 AM
ei8ht
Aug 21, 2017 09:08 AM
