FS Blitz R-VIT i-Color FLASH
R-VIT i-Color FLASH BLACK used for 6 months boxed.
Flash it's good for Mazda Cars.
R-VIT i-Color Flash is a monitoring multi meter designed for 2003 or later Toyota CAN-bus or vehicles equipped with 1996 or later ISO14230 diagnostics connector. Installation is simple, it is install just by connecting to the vehicle diagnostics coupler. It features a 65,000 Color LCD screen and multi angle display. It can be set on three different angles depending on the location of the installation. R-VIT i-Color monitors a maximum of 29 items and able to display 6 monitored items simultaneously. Monitored items are: Speed, RPM, Water Temp, Ignition Timing, Fuel Injection Time, Air Flow Voltage, Outside Temp, Intake Manifold Pressure, Boost, O2 Voltage, O2 Rear Voltage, AF 1, AF 2, Intake Air Mass , Battery Voltage, Throttle Output, AT Temp, Gear Position, 4WD Ratio, Fuel Pressure, Momentarily Fuel Consumption, Malfunction Diagnosis Code, Lock Up ON ・ OFF, External Voltage Input (Press, A/F Box) / External Temp Input, Fuel Pressure Control, Fuel Injection Control / Electric Fan Control, etc. Depending on the vehicle, the monitored items vary or cannot be monitored.
Sell for 300 US$ with shipping from Japan using EMS with tracking number and insurance, arrive in 4-8 days (USA), payment with paypal.
Language: Japanese or English
System: Metric or USA (i.e. miles etc...)
If you have any question please ask, thank you.
JimmyBlack
273
Feb 10, 2020 10:23 PM
Touge
Canada Forum
Sep 22, 2015 11:51 PM
