View Full Version : Any FI guys/gals regret their install?
wildside50
02-09-2008, 11:57 PM
Has anyone found that FI has affected the overall balance of the car. I'm looking more to road race/autocross fans rather than the street racer. If you had it to do again, would you put the money elsewhere in improving the car?
eviltwinkie
02-10-2008, 12:07 AM
Most track addicts will spend money in the places it needs it first...FI is usually last on the agenda as most of the time, the car is faster than you as a driver can get it...by the time FI is added, the owner should know a thing or two about how it all works...
So 99% of FI track duty 8's will generally have competent drivers who have added FI for that added juice on those long straights that kills us...
That said...I doubt any of them regret it...
wildside50
02-10-2008, 12:17 AM
You trying to say I don't know how to drive? Hehe. If you are, that's okay, cause I don't. In fact I kinda suck (3rd to last in Autox 1 last year in my SRT-4, and dead last the second time). I'm working on that...
It just seems like the suspension, which gets so many raves, is just about perfect right out of the box. I don't really want to mess with it's balance between comfort and performance. Bigger and better tires, that's a given. But other than that... I don't know where else to go except FI. I'm not talking about next week, I'm just thinking for the future. No point in spending the next 6 months learning all I need to know for the Pettit SC if it turns out it's not a great idea for the track.
staticlag
02-10-2008, 01:35 AM
well, spend any time on a track and your going to need a new radiator and the mazmart water pump.
staticlag
02-10-2008, 01:36 AM
+1 :)
wildside50
02-10-2008, 04:09 AM
So I take it cooling is an issue in the RX-8?
olddragger
02-10-2008, 09:15 AM
Uhhhhh Yea! Plus i had rust on the Mazmart water pump impeller.
I fi'ed and no regrets---you can never go back.
oldscdragger
mysql101
02-10-2008, 10:05 AM
The only time you regret fi is if your engine blows. Otherwise you are in nirvana.
eviltwinkie
02-10-2008, 10:08 AM
Yeah..basically...heh
I added the MS suspension, PT sways, RPF1's, Toyo R888's...
And it was like night and day...
The car is way faster than I am capable of now...still...and even more so...
Learning to watch what the car is doing is vital...get yourself some good gauges...when you begin to bump into the limitations of the car, you will know your ready for the next step...
The first indicator...temp...when you need better cooling...you have graduated preschool...heh
eviltwinkie
02-10-2008, 10:10 AM
Technically...yes and no...
If your fast enough on the track...yes
For daily driving, or new to the track...probably not*
*Climate is a variable...
mdw1000
02-10-2008, 11:21 AM
Definitely climate has a lot to do with it. I've done one track weekend with my 4AT. I've got the scangauge, and my water temps never got above 212. That was before the mazmart water pump was installed. But this was in Michigan in September. The highs were in the uppers 70s F.
mdw1000
02-10-2008, 11:23 AM
oldscdragger
olddragger,
What kind of coolant mix ratio were you running with this?
mdw1000
02-10-2008, 11:26 AM
Where I'd like FI for the track is for passing power. At the end of my track weekend, when I started passing other cars, I noticed that some more power would be nice to be able to finish the pass quicker. I am thinking this way because most of the tracks I will go to have very short straightaways, and I plan on staying in the lower run groups for a long time where passing is allowed only in the straights.
As far as suspension mods, after one track weekend I'd definitely recommend sway bars. I think it will make it more comfortable to drive on the track with less body roll. I was getting aggressive enough by the end of the weekend that I was really getting a lot of body roll, really pushing me into the door.
I'd also like it for passing power on two lane country roads when I've got other people/dogs in the car. But that is off topic for this thread.
dannobre
02-10-2008, 01:07 PM
I regret not doing it sooner...I waited until my warranty was up........:)
wildside50
02-10-2008, 01:08 PM
Well, I'm convinced. The RX-8 just isn't the car for FI. It would cost a good 10k to do it right, and now you're talking about a car that has near as much money in it as a Porsche Boxster or Corvette.
I think my first mod will be the Skip Barber mod. Second mod, track day mod. Third mod, second-job mod...
eviltwinkie
02-10-2008, 01:14 PM
Heh...you have much to learn...
The times they change and the wind whispers of RX-8 FI glory...
The single largest hurdle has been engine manglement...and that hurdle is about to disappear...
Spend your time becoming a better driver...
When you are ready for FI...~$4-5k will be all that is required...
Oh...and as long as you are reasonable and take your time...it should not cost an arm and a leg...
Jedi54
02-10-2008, 01:52 PM
^^^ he's telling the truth!
With the help of some people in this community, FI is becoming a much more viable option in the near future. Development and advancement is happening faster then ever with this car and $4-$5k should be very reasonable soon.
olddragger
02-10-2008, 02:34 PM
The increased power and torque does change the way you drive the car on the track. before Fi you could get on the throttle very early and you could brake later(not carrying as much speed), the rear end can now brake away MUCH more easily. You will find yourself having to take the "muscle car line" after FI and you will understand what it really means to have a cool down lap.
oldscdragger
HiTMaNN
02-10-2008, 03:47 PM
Pussy:icon_no2: :icon_no2: :icon_no2:
SlideWayz
02-10-2008, 03:54 PM
oldscdragger
+1
When I drove it FI for the first time with the traction control off, I wanted to bring the back end around a little bit so I gave it some juice and...
...it broke loose all right: I let off the gas and turned the wheels in the direction of the spin but still wound up doing a 360 degree spin. It was like driving on ice once the back tires lit up.
Whoops!
eviltwinkie
02-10-2008, 04:09 PM
+1
Whoops!
Momentum...gets you in the end...heh
Rote8
03-04-2008, 04:06 PM
I only regret it when it's time for new tires......
Jedi54
03-04-2008, 04:12 PM
I imagine you also regret it slightly when you get your Gas card bill but then again...who gives a crap about mpg! :)
Grouch
03-04-2008, 07:53 PM
even though my car is not runnin perfect right now (which has nothin to do with the turbo), I don't regret it at all. it was the best thing I did to my car and it transformed it and it's like having a totally different car. As a daily driver you cruise around at lower rpm's and it's much more comfortable and relaxing and now i can blast up hills without needing to redline it to pass people.
you can get a greddy kit, bov and cobb accessport and be done with it, all brand new for about the 4k mark and for less than a few grand more mods you can have a killer kit
dannobre
03-04-2008, 07:58 PM
I only regret the gas bill...
but who notices it :D:
NgoRX8
03-04-2008, 08:05 PM
i drive a lot of city now, and i didn't notice how much a difference it makes compared to highway. i'll be sure to track it when i'm turbo'd. hahah
Razz1
03-04-2008, 10:51 PM
Your WIFE ! :rant: gas mpg :rant: :rant:
When are you going to moe the lawn? :rant:
Big_Mike_4488
03-04-2008, 11:03 PM
HA! I was just about to ask you guys how in the blue f*ck did you convince your significant others to let you spend 5K on FI?? I am still trying to come up with the reasoning for my fiance... :banghead:
dannobre
03-04-2008, 11:07 PM
The easiest way is not to ask......
HiTMaNN
03-04-2008, 11:35 PM
Ahhhh I love being single.....
pdxhak
03-04-2008, 11:52 PM
exactly
pdxhak
LOL it is time to sack up!
ChattyRX8
03-05-2008, 12:49 AM
exactly
It's easier to ask for forgiveness than it is for permission.
Big_Mike_4488
03-05-2008, 12:59 AM
Well I'm engaged right now, not married. So I got a year left in which my money is my money. Got a year to save up enough to blow on a turbo!! :)
Rocketman1976
03-05-2008, 10:38 AM
Just convince her its a good investment... You'll be in a better mood all the time after your FI'd!
Jedi54
03-05-2008, 11:17 AM
damn right.
Bastage
03-05-2008, 01:44 PM
Man, all these people talking about asking their wives...
I didn't have to go through any of that crap, I just told her I was going to do it and she was totally cool with it... I'm SO going to buy her some flowers today, just for the heck of it. :)
HiTMaNN
03-05-2008, 01:47 PM
Awww your such a Sap! :uhh:
dothackRAVE
03-05-2008, 01:48 PM
See, that's why I don't wanna get married. Women do little but get in the way!
Grouch
03-05-2008, 02:11 PM
She's been complainin about my CEL a lot recently, so I saw the opportunity to take it in to get some 'work' done. She was a bit naive about the cost when I went to pick it up. The only thing that didn't work out was that the CEL was still on because some of the work wasn't finished yet, lol.
