Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
engine dying?!?!?!?1
Old Feb 9, 2008 | 05:39 PM
gothamite's Avatar
whenever i am driving around and i come to a stop the engine seems to stutter and then die. if i keep it revved it still seems to be inconsistent... anybody ahve any ideas what this is or know of a good mechanic i can take it to to get it checked out? also the sound seems to have changed at low RPMs...
i am also a n00b to rotary so any help is really apprectiated
Old Feb 9, 2008 | 05:55 PM
DarkBrew's Avatar
Extraordinary Engineering
Some additional info would help/
Year
Mileage
maintenance history
driving style
Old Feb 9, 2008 | 07:04 PM
chancejat's Avatar
Drive it like u stole it!
first check you maf sensor....then make sure all you tubes etc...on your intake are connected....also check your spark plug wires for security....if none of that helps than it could be bad coils....sound change??? my guess would be coils...have you had any power loss at high rpms??
Old Feb 9, 2008 | 07:07 PM
A bad charging system can do this too. A bad battery, so check that.
Also check the plugs and air filter.
Old Feb 9, 2008 | 07:25 PM
sandnsun7's Avatar
same symptoms
I just had the same symptoms on my '04, took it too the dealer and they found that the O2 sensor was bad. Replaced it, idles fine.
i noticed before it was replaced that the exhaust had a different smell as well as the idle problem. My CEL light came on eventually when it got worse.
Old Feb 9, 2008 | 08:03 PM
gothamite's Avatar
Year
Mileage
maintenance history
driving style
2004
37K
no real maint history
driving style? i dont drive like a grandma but im no speed racer either... lol
Old Feb 9, 2008 | 10:00 PM
stuff mentioned above, also check to make sure the plugs are tight.. for that matter you should repace them..
i would also replace the coils.
Old Feb 13, 2008 | 01:57 AM
gothamite's Avatar
MAF was the culprit
thanks to all who gave suggestions and offered help...
and sorry i am just getting to post this but i have been hella busy
Old Feb 13, 2008 | 08:31 AM
skwidd's Avatar
ZEE-non
Originally Posted by gothamite
speed racer
GO SPEED GO!!!!
vapor2
Nov 3, 2020 03:38 PM
Skyl3r
Dec 2, 2019 04:51 PM
harithac
Aug 17, 2015 09:14 AM
Eirulisse
Aug 15, 2015 12:34 PM
Bamaham
Jul 23, 2015 08:08 AM
