View Full Version : wheels squeaking?
philsbluerx8
02-07-2008, 02:20 PM
i searched but no results about wheels squeaking
yesterday i put my new rims and tires on and they 18x8.5 +38 with 245/40 R18 all around. After i went out from the shop, the front wheels sounded like squeaking. i dont think it was about the breaks cuz i just replaced my hawk ceramic break pads about 4k kms before. then what should it be? anyone could give me some ideas?
c41250n
02-07-2008, 02:42 PM
did it squeak only when you're on your brakes?
or does it squeak when you're going slow?
TopGear8
02-07-2008, 06:20 PM
Take the wheels off, then put them back on. Might work..
Razz1
02-07-2008, 09:50 PM
Check the tires. You may be rubbing on the outside or The inside may be scraping the SC.
Jedi54
02-07-2008, 11:15 PM
make sure the lug nuts are properly tightened
philsbluerx8
02-08-2008, 11:44 AM
i used stock ones but they said its a little bit too tight, but it fit very well;
its squeaking when low speed.
and they found out that my left tie rod is loosened. but i dont know what exactly it means but i will let the dealer check it out.....
i will also try remove and put them back.
