Which oil is the best?
Old Feb 2, 2008 | 06:38 PM
markryan22's Avatar
SFC
Just curious on what oil gives the best performance for the 8. I always take it to the dealer but I want more out of my engine.
Old Feb 2, 2008 | 06:43 PM
CTrx8's Avatar
space for rent
canola
https://www.rx8club.com/rx-8-discussion-3/oil-brand-poll-78494/
Old Feb 2, 2008 | 06:57 PM
U failed.
Old Feb 2, 2008 | 07:00 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Wow........just wow................it's all I got.
Old Feb 2, 2008 | 07:03 PM
markryan22's Avatar
SFC
Royal Purple? So if I go with that I'd get the 5W20?
Old Feb 2, 2008 | 07:06 PM
Mazurfer's Avatar
Mark......do a search and you'll see what grade others are running if synthetic.
I don't want to steer you wrong.
Anyway.......you need more than three characters when searching...........try "synthetic oil"
Old Feb 2, 2008 | 07:07 PM
deadphoenix52's Avatar
meh.
i use vegetable oil. its better for the environment.
Old Feb 2, 2008 | 07:09 PM
markryan22's Avatar
SFC
alright thanks
Old Feb 2, 2008 | 07:10 PM
I use Mazola
invasion08's Avatar
I like to use castrol gtx. The rx8 is designed to burn oil and synthetic burns at a high temp then normal oil. synthetic oil will not hurt the rx8 i just see no need to spend the extra money for synthetic oil.
Old Feb 2, 2008 | 07:16 PM
markryan22's Avatar
SFC
see I'm all new to engines and all that stuff so i'm trying to get the most out of it. I just seen a thread about spark plugs lol and I'm like should I change that too. (30,000 miles on my engine)
Old Feb 2, 2008 | 07:20 PM
invasion08's Avatar
Yes to get the most out of your car the spark plugs should be changed every 30k.
www.autopartswarehouse.com sells them for 85 dollars shipped and thats the best deal i have seen. Look in your owners manual it will tell you when you should change or replace things. Aslo change your oil and oil filter every 3k
Old Feb 2, 2008 | 07:41 PM
07rx8gtblack's Avatar
Leave our Dok-do alone!!!
I just use the castrol gtx 5w-30 myself. I might order the synthetic oil designed for the ratary engines. I have a new car and just take it to the dealer for the oil change. They use 5w-20. It appears to me, though, that 5w-20 burns faster in the engine. That's why I just go with 5w-30 when I add oil.
I don't know... It's one of those things that everyone has an opinion or two.
Old Feb 2, 2008 | 07:43 PM
MAZOLA
Old Feb 2, 2008 | 07:44 PM
invasion08's Avatar
I use 5w20 and check it often
Old Feb 2, 2008 | 07:45 PM
DOMINION's Avatar
I don't buy Kool-Aid
RP is da best!
Old Feb 2, 2008 | 07:51 PM
invasion08's Avatar
RP is ok if you like to pay double for oil
Old Feb 2, 2008 | 07:53 PM
Jasonawojo's Avatar
I use Royal Purple 5w20; engine is still intact.
Old Feb 2, 2008 | 07:55 PM
invasion08's Avatar
How much does a QT of RP go for?
Old Feb 2, 2008 | 07:57 PM
Jasonawojo's Avatar
I get it for $6.49/qt (free shipping, most likely no tax) at http://www.americanmuscle.com/
Some on here buy it in mass quantity for less I believe..
Old Feb 2, 2008 | 08:01 PM
invasion08's Avatar
oh ok just wondering I can get alittle more than 2 QT's for your one RP. I am thinking about using it my bike
Old Feb 2, 2008 | 08:11 PM
Mazurfer's Avatar
And if you don't have a manual, you can download it for free in the owners ection of www.mazdausa.com
Yes, you'll have to sign up(free of course), but there is a lot of good info there and it will show if there are any recalls not performed yet on your car.....as just one example.
Old Feb 3, 2008 | 01:38 AM
extra virgin olive..
Old Feb 3, 2008 | 02:05 AM
DOMINION's Avatar
Old Feb 3, 2008 | 06:12 AM
Startl_Respons's Avatar
So IF you are new to engines and all that stuff, THEN you want to get the most out of it? Therefore IF you don't want to get the most out of your engine, THEN you are not new to engines and all that stuff.
I use hydraulic jack oil. The reasoning is because you need to jack up your car and so you need to try to get the most out of your jack. In addition, hydraulic jack oil adds approximately 5-8 HP on my RX8. Something to do with the "hydraulic" characteristics and additives.
Hey, very importantly, did you read the article in which people using a combination of dino oil and/or synthetic had their engine literally blow up while cruising on the fwy? There was a double dissociation where 1:1 of two kinds of dino oil produced a significant effect whereas a 1:1 of two kinds of synthetic did not produce the effect. However, when a 1:1:1 of three kinds of oil, whether all dino or all synthetic or any 2:1 combination of 2 kinds of brands whether two parts dino and/or two parts synthetic notwithstanding led to nothing more than a misuse of your money that they will perform.
Hope this helps.
