Automatice Transmission Fluid
Old Feb 1, 2008 | 10:03 AM
darkness20069's Avatar
hi,
i have a 2004 AT. Its time for my 60K service and I don't live in an area where there is a mazda dealer...anyways the owners manual says the "manual transmission fluid" needs to be replaced but doesn't talk about the AT.
Should I replace it?
Old Feb 2, 2008 | 12:29 PM
bxb40's Avatar
Rotary Newbie
It should have been replaced sometime ago... I used RedLine High Temp ATF in mine at 30k. Change the rear differential oil as well. Do a search for details on that - you can do it yourself, if you are not afraid to get a bit dirty ;o) Not sure you can change the ATF yourself though - but if you get the ATF and the filter, another shop should be just fine.
Old Feb 3, 2008 | 05:56 AM
Vertigo-1's Avatar
I do a complete fluid flush at the end of the year for all fluids. Man, I pity your tranny if it's only getting a AT fluid change now at 60k miles..........
Old Feb 3, 2008 | 11:46 AM
thanks for the info. i'll do a complete flush.
Old Feb 3, 2008 | 02:04 PM
Old Rotor's Avatar
Did you know of this TSB on changing the ATF.....
http://www.finishlineperformance.com...14-06-1714.pdf
theblinkof
Oct 4, 2023 05:24 PM
airlive
Jun 28, 2020 07:46 AM
XianUnix
Sep 29, 2015 03:48 PM
