NW RX-8 Forum Serving WA, OR, ID, AK
Spluttering exhaust / high pitch sound?
Old Jan 31, 2008 | 06:22 AM
BBoyAkay's Avatar
Cool Spluttering exhaust / high pitch sound?
Hi there!
I have just bought a brand spanking new RX-8 and am VERY happy with it. It's a 6 speed 231BHP red rx8 and boy does she look sweet The last 24 hours have been a continuous ride of thrills and excitement.
However...
I do have some questions, im not sure if its because the car is new, im paranoid or if its just normal.
1. I'f im in neutral and giving her some "gas"...upon "wind down" the exhaust gives off a few what i would call "splutters"...is that normal?
2. If the rx is just ticking over in neutral, the engine sound tends to be a bit of a high pitched whine. Its not annoying or anything, just kind of a worrying new sound for me...
If you could shed any light on my worries it would be much appreciated, thanks!
Akay
Old Jan 31, 2008 | 06:59 AM
Spin9k's Avatar
Momentum Keeps Me Going
Congrats and welcome to the forum. Your life has improved immeasurably what with your beautiful new RX-8 to look at!!! That's normal of course, we've all been where you are now
1) yes
2) Being a rotary, it's sounds are all new to you. Forget your previous piston sounds, there aren't any. Enjoy the new song ( and don't forget after your breakin is done, redline the engine regularly!)
spin
Old Jan 31, 2008 | 07:26 AM
BBoyAkay's Avatar
Thanks for the reply spin!
For curiosity's sake, what exactly are those splutters then?
Old Jan 31, 2008 | 07:32 AM
Spin9k's Avatar
Honestly don't know....one of life's little mysteries I guess (but I'm sure someone else will chime in!)
Old Jan 31, 2008 | 12:38 PM
jisoo26's Avatar
RX-8 dreamer
I'm no rotary expert but if I were to guess what those little "sputtering" sounds were, I think they're the rotors slowing down to a stop...since they spin as opposed to pumping up and down like pistons.
Dunno about the high pitched whine, can you describe further? I know that in the first start up in the morning, the engine gives a slightly higher sound then goes to a lower one after about 10 seconds when it drops from 2k to 1.5k rpm...
Old Feb 1, 2008 | 07:49 AM
BBoyAkay's Avatar
Thanks for the replies!
Yeah, i think the spluttering is normal...at least i hope so!
As for the high pitched whine...well it sound exactly like what you explained. I immagine its just the rotary engine heating up.
Thanks again for your input.
Akay
Old Feb 1, 2008 | 12:14 PM
mmats69's Avatar
93.5 octane
are you hearing that whine when you are in neutral and the clutch is out? if so, that is normal
Old Feb 1, 2008 | 12:58 PM
Nemesis8's Avatar
Bigus Rotus
Make sure you do the proper breakin procedure for the motor also
Old Feb 2, 2008 | 12:28 PM
patrick_andraste's Avatar
Gotta Love Two Strokes
the high pitched whine in my RX-8 is caused by the Air pump electric motor.
Old Feb 2, 2008 | 10:38 PM
kristopher_d's Avatar
Drive Master
The "splutters" are backfire. Normal, especially for the Renesis.
Proper break-in procedure is to redline the engine on every shift for the first 70000 miles. Then redline every shift for the next 70000 miles and repeat as necessary.
The "whine" is probably actually the transmission. The gears themselves are great, but the synchronyzers are crap, and they aren't helped any by the flywheel. On up shifts, especially in the lower gears, you'll want to be sure the revs come back down before grabbing the next gear. On down shifts, a little heal-and-toe and double clutching will go a long way. Not all necessary all the time, but I certainly wish I'd been a little nicer to the tranny.
As for the engine. Flog it. Flog it hard. If she aint screamin', you aint playin' hard enough.
Old Feb 4, 2008 | 05:54 AM
BBoyAkay's Avatar
Great, thanks for you input guys.
What do you mean by "redline" the engine on every shift?
Old Feb 4, 2008 | 06:23 AM
Spin9k's Avatar
Look at your tachometer. OK. See the red line on the dial markings up about 8500RPM? That's the 'redline'. People were saying "make the pointer go there, the 'redline' on every shift". But don''t take that advice 100% seriously.... It's simply a figure of speech rotorheads use!
Just do that when you want to, when it's fun and safe, and when you need the extra acceleration. Times like that.
Old Feb 4, 2008 | 04:10 PM
Drive Master
Okay, so redlining EVERY shift is probably not necessary. But don't baby the engine either. The last thing you want is carbon build up causing you issues down the road.
Old Feb 5, 2008 | 03:44 AM
BBoyAkay's Avatar
Great, thanks again guys.
So when people "redline"...do they push that far so the warning sound beeps?
Old Feb 5, 2008 | 07:03 AM
Spin9k's Avatar
Use the beep like the sound from a radar detector, after a bit you never bother to look down, just drive by sound...you know....whiiiirrrrrrrrrr Beep! wurrrrrrrrrr Beep! wiurririiiiiiiiir Beep! (now your going 95mph!) Wasn't that fun?
Old Feb 5, 2008 | 08:00 AM
BBoyAkay's Avatar
Haha, okay Spin9k, thanks for the input ;-)
ktec
Jun 26, 2021 10:18 AM
IamFodi
Series II Interior, Audio, and Electronics
28
Oct 31, 2018 06:37 AM
dbarber
Jul 25, 2015 01:34 PM
ironj221
Jul 16, 2015 10:16 PM
AussieGray
Jul 16, 2015 03:58 AM
