Zelse
01-27-2008, 12:51 AM
Hey guys,
So I got a curve ball to throw at anyone who is Rotary savvy. Now I'll tell you right now, I'm no mechanic and no rotary god..But I know what a Rotary is, how it works, what to do with it and what not to do. So at least give me that...But this happened the other day.
I took the car to the dealership due to a check engine light..and he said it was the Cat being all clogged with "fun stuff" we'll call it. Apparently, it has to fail a test of 0-7.99...so it has to be over 7.99 for it to fail and be covered under warranty. I AWESOMELY passed the test with a 7.39. They wouldn't replace it on the spot and said to come back when it starts to affect my daily driving, and that apparently it wouldn't damage the engine if it went. So... I took my car and off I went.
A day later..Driving home from work.. I noticed.. After 4k RPM...the car felt like it had absolutely NO power. None. Just like it was going and that was it. Best part is.. it took forever to rev up, and it wouldn't go past 7k rpm. After a bit, the check engine light started flashing and I smelt smoke. Thats when I really knew something was up (and of course the fact the car felt like a 150 HP car and not a 240HP car...) So I took her to the dealership this morning... Low and behold.. The Cat did damage.
He called me later to say that because the cat was so clogged with crap, fumes went back into the engine and misfired a rotor, causing the sparkplugs to go and make me run on 1 rotor. Soo... Apparently I have to wait a couple days and see what happens. They ordered new plugs and apparently a whole new "Converter Set".
That being said.. I know the dealership knows their stuff, but they surprised me on this one, and I don't know if I can count on them to gamble my engine like that. So my question to anyone out there is...Is there anything I suggest for them to check out as well? Anything you guys think happened to the engine? My rotary buddy says most likely the engine is fine and shut down the rotary as a precaution to not hurt the engine...Sounds feesable..But I'd like to just make sure is all. I don't want to visit the dealership again sometime soon just because I didn't have them check something out while it was there.
Thanks for the feedback everyone, and happy motoring.
UPDATE: 4/09/2008 I know it's been a little bit but felt this would be a good knowledge base for everyone. I noticed I forgot to mention that the original reason I went to the Dealership and how they found out the cat was clogged was because I was seriously lacking in low end power... It just felt like the car was "going" and not actually GOING..Hard to explain. Thats where they did the test. Now..Notice the numbers I provided everyone with.
They said I got a 7.39 and it was passing..and that a 7.9 is a fail. The tests go from .0 to 8.1 ... Apparently..4.60:1 and up means your catalytic converter is toast. (http://www.coremazda.com/tsb/rx8/rx8-repair-procedures-recall.pdf) So.. This dealership openly didn't give a rats and lied to me about it in the first place. Thanks Astral for that knowledge as I know I will NOT be taking my car there again for anything..Period. For all, just making sure you know, it was the Nashua NH Mazda Dealership known as Tulley. Plus, it's apparently Inconvenient for them to take your car in on any weekend or weekday other then Monday. Plus they also close at 5. I'm a working person with a 9-5 job..so.. really hard to get time off work for these guys. Won't need to anymore anyways. F that. Just letting the community know.
